What did you do today
Re: What did you do today
Postby bdosborn » Sat Mar 26, 2022 6:29 pm
I used a Bafang mid drive kit from Amazon, it has everything you need but the battery. Bafang is one of the best DIY kits, IMHO. I like the mid drive motor as it is better on hills than a hub drive but has a lower top end. It's more expensive too. 750W is good for us and I wouldn't go any lower. We have a 20-30 mile range, depending on how many hills there are and how hard you peddle.
Bafang Mid Drive
I used a 48V, 13ah battery as that was the best bang for the buck 2 years ago. I wouldn't go any lower than 48V and I would look at a 52V battery for a higher top end. I can go 30 mph, down hill and pedaling hard.
Battery Link
Here's a couple of forums I visited when I was doing my research:
https://endless-sphere.com/forums/
https://electricbike.com/forum/
Images: 806
Postby flboy » Sun Mar 27, 2022 7:45 pm
Here is what I used
Front wheel drive. Don't use this if you plan to use bike for offroad. A Rear or Mid-drive would be better off-road.
Great for normal bike use and balanced well when battery is on a luggage rack on the back with the heavy motor hub up front..
Hub:
AW Electric Bicycle Motor Kit 48V 1000W 26"x1.75" Front/Rear Wheel Powerful Motor E-Bike Conversion Kit w/LCD Display https://www.amazon.com/dp/B00YBWA5VC/re ... UTF8&psc=1
Battery: need to put in a case on luggage tack.
7 Styles of 48V Lithium ion... https://www.amazon.com/dp/B09D7273KC?re ... b_ap_share
This is a video how I built the bike:
https://youtu.be/jLEzE35ZQSo
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Wed Mar 30, 2022 3:01 pm
Two days ago I got a flat tire about 1.5 miles from home on the way back from a 12 mile trip. Had to walk it after the flat. So today I installed some wider (and taller sidewalls) heavy duty tires along with some premium heavy duty inner tubes that I can run at 55lbs air pressure. I think the rear tube pinched when I jumped up on a curb doing about 15 mph. I heard the metal on the Rim bang.
In any case, added better tires and tubes along with a pump and spare tube to replace on the road if needed.
Also added the equivalent of a tank bag on the top bar for the phone, wallet and etc. and improved brake pads so I can stop much quicker. This does not have disk brakes and the pads were old as the bike. Did not stop quick enough for me when going 30mph. Wish it had disk brakes, but used what I had.
Got it dialed in and working well..nice ebike for having only $700 in it now since I already had the bike.
I have also ordered some torque bars for both ebikes. These 1000W motors have alot of torque and I am concerned the axle may spin in the slot as there is not alot of good hard metal to prevent that in the fork slots. Cheap solution and I can forget about it.
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Wed Mar 30, 2022 3:15 pm
Put slime in your tubes or your gonna get more flats. I resisted it because I don't like fix-a-flat type stuff but flats went from a ton to none after I added it to both bikes.
Slime Linky
P.S. The Maxxis Holy Roller is a great front tire for dirt and road (if you have 26" rims).
Images: 806
Postby flboy » Wed Mar 30, 2022 4:11 pm
bdosborn wrote:Put slime in your tubes or your gonna get more flats.
Thanks for the tip. I ordered some and will add to both bikes. I hate getting flats and it seems it doesn't take much for bike tires.
Don (Flboy)
flboy
Images: 378
Postby MickinOz » Wed Mar 30, 2022 4:56 pm
Can you get this one in your neck of the woods?
It outruns everything else I've ever tried by a country mile. Fixing the kids bikes was a weekly ritual before the local auto parts store started stocking this one.
https://www.truebluegoo.net/page/page/7153432.htm
MickinOz
Postby flboy » Wed Mar 30, 2022 5:19 pm
Sounds like Slime, but blue instead of green. Maybe recipe is different, but same idea.
Don (Flboy)
flboy
Images: 378
Postby MickinOz » Wed Mar 30, 2022 9:32 pm
Yes, it is like Slime, but it's waaayyy better.
MickinOz
Postby bdosborn » Thu Mar 31, 2022 10:34 am
I can't complain about slime, I've had zero flats since I added it to my tubes.
Images: 806
Postby flboy » Thu Mar 31, 2022 5:01 pm
I added the torque bar to the E-bikes today. This should mitigate any bad affects of the rotational torque from the 1000W motor on the axle slots in the forks. That's the thought anyway.
I also figured put how to enable the Cruise Control feature via the LCD advanced setup and then engage it when up to speed. The manual that comes with the kit is worthless. Cruise Control works great, nonetheless.
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Thu Mar 31, 2022 5:48 pm
Start saving your pennies, this is where an ebike obsession might take you:
https://lunacycle.com/sur-ron-x-bike-black-edition/
:money:
Images: 806
Postby Staryder61 » Fri Apr 01, 2022 2:23 pm
bdosborn wrote:Start saving your pennies, this is where an ebike obsession might take you:
:money:
Now if someone would make a kit for my Unicycle, :roll: :thinking:
scrap that idea, thought I'd check before posting this. And there it is. But they forgot the pedals.. :frightened:
Mine I had to learn to ride with the pedals.. :thumbsup: and some scars..
https://x-offroad.com/super-ride-s1000- ... cycle.html
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby flboy » Fri Apr 01, 2022 3:27 pm
:money:
Now you did it! Lol
Actually, I have been eyeing some street legal versions for various travel related reasons. Just not ready to shell out the $ yet.. but I can see that in a few years.
Still keeping the "gasers" in the meantime.
Don (Flboy)
flboy
Images: 378
Postby MickinOz » Sat Apr 02, 2022 10:25 am
I woke in my teardrop at Pekina Reservoir. I had a brilliant nights sleep. Nice spot. The council dstrict this dam lies in has decided to be "RV friendly" and it shows.
Plenty of free campsites. Some signposted no time limit! I had breakfast then continued north. Made it to Blinman in the northern Flinders Ranges. Its an old mining town. Met up with friends for dinner at the pub. Now camped behind the pub.$10 gets a campsite for the.night with s key to the toilets and showers. It pretty good, except the whole town is powered by diesel generator. Its not super loud, but I can hear it.
Mine tour in the morning, then I'll start the journey home.
Info for slowcowboy. Its 200 miles from home to this old Outback in imining town. $140 worth of diesel.
Also for slow: I
I'm starting to see why your posts sometimes seen a little disjointed. What a PITA trying to post from my phone.
MickinOz
Postby Tom&Shelly » Sat Apr 02, 2022 11:24 am
MickinOz wrote:What a PITA trying to post from my phone.
+1. We were on the road the past two weeks. I finally gave up trying to follow tnttt, much less post, using my phone!
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2294
Users browsing this forum: Google [Bot] and 10 guests
