What did you do today
Re: What did you do today
Postby bdosborn » Wed Apr 06, 2022 7:57 am
flboy wrote:For levels, I have a simple visual for fresh water and a gauge for the graywater level, but because I like meters and wiring, I may add a float sensor and same analog gauge (~$25.00 on AliExpress with float and gauge) to the FW tank also.
I bet you could add the floats and use a multipole rotary switch so that you only need one gauge to read tank levels.
Images: 806
Postby flboy » Wed Apr 06, 2022 11:34 am
I could for sure, but since the sending unit and gauge come as a set, I will just use both gauges. Going to mount the FW Gauge by the Pump Switch on Appliance stack. Already have the GW Gauge mounted on the water heater pipe cover in the bathroom along with the switch for the GW Tank Heating Pad..
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Tom&Shelly » Wed Apr 06, 2022 12:51 pm
Two weeks ago we found this in the trash at Catalina State Park AZ, and I finally set it up to see why it's trash
168794
Looks good enough to use...for something, anyway. Don't think we need another camp kitchen table, but ya never know. Must have seen its share of camping. A few of the aluminum support braces are broken, but I could replace those with aluminum strap, drill out the rivets and replace with screws.
Evidently, there used to be a storage net under the table, but that's missing. The thing even had set up directions taped under the table (aka: inside the storage case)
168796
Was supposed to have two brackets to hold a grill, but there were four, so the previous owner must have picked up an extra pair somewhere. They also added some after market rubber to them with double sided tape that has now deteriorated
168795
Looks as useful as many of the things we have in our bins of camping gear. :ok:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2294
Postby TimC » Wed Apr 06, 2022 1:20 pm
Tom&Shelly wrote:Two weeks ago we found this in the trash at Catalina State Park AZ, and I finally set it up to see why it's trash ...
Nice find!
Tim
Niagara, WI
TimC
Images: 751
Postby Staryder61 » Wed Apr 06, 2022 1:42 pm
Tom, it's amazing what some throw away as trash. ;)
Years ago we found a 10 ' x 10 ' EZ up awning, frame and canvas laying next to a dumpster in a camp ground.
Curious me, picked it up, took it to the camp site. It had two rivets that had popped out. Fixed with a couple bolts and nylon nuts
from a assortment kit I carry camping for just such things.
Have been using it ever since. 3 maybe 4 years now..
So :thumbsup: up on the find.
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby Tom&Shelly » Fri Apr 08, 2022 4:15 pm
Today I made some repairs on the banister for the (outdoor) steps up to our cabin, that suddenly came loose this morning. I believe the carpenter who built those steps is now doing school bus conversions somewhere in Texas... :frightened:
Tom&Shelly
Images: 2294
Postby bdosborn » Fri Apr 08, 2022 7:31 pm
Tom&Shelly wrote:I believe the carpenter who built those steps is now doing school bus conversions somewhere in Texas...
His name isn't Ben is it? :thinking:
Images: 806
Postby Tom&Shelly » Sat Apr 09, 2022 9:59 am
:lol:
Tom&Shelly
Images: 2294
Postby MickinOz » Sun Apr 10, 2022 5:27 am
Today, I watched this. I do hope you guys can see this wherever you are in the world.
I had read that the president of Ukraine was a comedian before he was elected.
Today I stumbled across this series "Servant of The People".
I've only watched the first episode, but seems to me he sure is a funny bastard. This is classic.
https://www.sbs.com.au/ondemand/watch/2013414467775
MickinOz
Postby theicomguy » Sun Apr 10, 2022 6:48 am
Installed new drums and brake kit on my axle. When I ordered the trailer they wouldn't add brake kits to the 5' wide trailer. not sure why but Dexter had all the parts I needed and took an hourish to do. Now to run wires and hook up to the block.
theicomguy
Images: 14
Postby Staryder61 » Sun Apr 10, 2022 11:52 am
MickinOz wrote:Today, I watched this. I do hope you guys can see this wherever you are in the world.
Unfortunately Mick, this is what I get on a page when I click that link above..
You appear to be outside Australia. Due to publishing rights most of our videos are only available in Australia.
but Thanks for trying to share..
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby Staryder61 » Sun Apr 10, 2022 11:55 am
That wasn't a good enough answer.
so dug further and found it here in the states on Netflix at :
https://www.netflix.com/watch/80119383?trackId=14170286
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby friz » Sun Apr 17, 2022 8:27 am
Happy Easter!Image
The "Sin Bin"
150133
friz
Images: 6
Postby flboy » Sun Apr 17, 2022 4:40 pm
Now that looks like it is going to be tasty! Happy Easter back to you.
Don (Flboy)
flboy
Images: 378
Postby twisted lines » Sun Apr 17, 2022 8:35 pm
Still Sticking Scraps together; Light weight Ply :thinking:
22" X 4' = 1 tube 1 side :shock:
1 tube.jpg (45.21 KiB) Viewed 733 times
Light Ply.jpg (45.35 KiB) Viewed 733 times
Racking up; And Rapin foam
twisted lines
