nikwax wrote:...well, that's too bad about the U Haul site. It was spot on for my two current vehcles and the truck I used to own. I've had very good experiences with them installing hitches and wiring. The lifetime nationwide warranty was a big plus for me as well.
I suspect that many Sienna owners think the U-Haul site is correct as well, since - like most drivers - they don't actually know what their vehicle limits are.
U-Haul trailers are generally intended to be towed by U-Haul trucks, and their system still works pretty well for full-sized pickup trucks. Throw a smaller tug in the mix - the subject of this thread - and the assumptions behind their trailer specifications become invalid. The tow vehicle specifications are obviously wrong in general, but may well be right in some specific instances, and if that's what you own it works out.
We've had discussions before about U-Haul stores and dealers; I won't rehash that here (it would be redundant, and this thread is about small tugs), but the summary is that not all U-Haul locations are created equal.
For a 2008 Honda Civic base model 4-door (an arbitrarily chosen Civic)...
- - the U-Haul hitch site finds the Sportframe hitch (24763) and lists a 2000 lb weight-carrying trailer capacity
- Draw-Tite lists the same hitch (same part number), with a 2000 lb trailer weight / 200 lb tongue weight capacity (it is also Reese 77139 and Hidden Hitch 60822)
- the Draw-Tite instructions correctly note "Do Not Exceed Lower of Towing Vehicle Manufacturer’s Rating or..." those ratings
- SUVOA lists zero towing capacity for all Civics (likely, Honda does not recommend towing)
- the U-Haul trailer rental system says that the Civic is "recommended" to tow the following trailers:
- 4' x 6' open (710 lb empty, 1500 lb max, no brakes, certainly unsuitable when loaded)
4' x 8' Cargo Trailer (850 lb empty, 2500 lb loaded, no brakes, even less suitable)
Sport Trailer (at 535 lb empty and 965 lb max the only U-Haul that might actually be suitable... but still no brakes)
Since U-Haul trailers are built for rental, they are rugged... and heavy. A reasonably sized teardrop might be okay for Civic, even if the same length of U-Haul cargo trailer is too heavy.
