Nice start. Cant wait tell you get going on this one. Id love to do something like this. The only place I can put a trailer is in my garage so under 7' tall will be cool.
Thanks for posting.
Dano
Lgboro wrote:@ Aggie79, Dexter has a air ride torsion axle very similar to Robs axle set up you might check out. http://www.dexteraxle.com
Lgboro wrote:Yeah I emailed Dexter to see if a lighter version is in the works or could be built. I'll post the answer if I get one.
I can't seem to find my way around their website I keep trying to find stuff on dropped axles and nothing
I've followed some of your discussions about the suspension design on other posts. Sometime, if you get a chance I'd love to see some more pics of your suspension design.
48Rob wrote:I have the air bags for the suspension adjustment, and raising/lowering.
A Panhard bar for side to side control, but am working through several ideas for towed ride height.
Junkboy999 wrote:That is a sweet little camper. As for little standups, Here is the all time favorite.
Woodie Love Bug
http://tinyhouseblog.com/tiny-house-con ... -love-bug/
48Rob wrote:
Anyway, it should be 96" long by 76.8 inches high. So this profile is just shy of 6'5" tall! With a dropped floor of a couple or three inches, I should be able to stand inside, and I'm 6'4".
Hi Kermit,
Can you clarify a couple things please?
You say the trailer will be 76.5" high, right?
You are 76" high.
A dropped floor of two or three inches adds a little headroom for sure, but...
How much space is there between the body and the ground?
How thick in inches is the roof/ceiling, and the floor?
I've been working on a trailer that allows me to fit it under a 7' garage door (84")
I'm 6'-2" tall (74")
That leaves me 12 inches, but you need a little clearance not to rub, so say 11 inches.
So the trailer can only be 83" tall, total, from the top to the ground.
I need 74" for me.
The roof takes 2" then the floor takes another 2.5, leaving 4.5 inches. (74+2+2.5=78.5-83=4.5)
You'll need at least that much for clearance between the body and the ground, and in reality several inches more.
Rob
