What did you do today
Re: What did you do today
Postby Tom&Shelly » Tue Aug 09, 2022 2:13 pm
bdosborn wrote:
tony.latham wrote:Just back from our annual detail on a lookout in the middle of the Selway-Bitterroot Wilderness.
Awesome views! Is there a stool with insulated legs to sit on during a lightning storm? 8)
I've taken enough EM fields classes that I wouldn't believe in that, except maybe if I were in a fire tower in the middle of a thunderstorm... :thinking:
On the other hand, I might start a wicked rumor that an all metal shelter on top of the fire tower acts like a Faraday cage and protects the occupants. ;)
Are there cases reported of fire watchers being struck by lightening?
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2294
Postby tony.latham » Tue Aug 09, 2022 2:40 pm
There's one. I suppose we could stand on that thing and hug each other for a while...
Are there cases reported of fire watchers being struck by lightning?
The lookout was built in 1947. It's heavily grounded with several runs of 3/8" copper wire. I don't know how many times it's been struck by lightning but in all those years, it's been struck, a lot. We took over from a guy that's been staffing this lookout for 51 years and has been inside when it's been hit several times. When we took over from him last year, the night before the shutter bolts were lit with St. Elmo's fire from the static during a storm. I really want to be inside when it gets struck. (Weird, eh?)
I don't believe the USFS has lost a lookout to lightning. Sadly, a lookout was killed this week when she decided to disregard an evacuation order at her home...
https://www.eastbaytimes.com/2022/08/08/mckinney-fire-very-respected-decades-long-forest-service-fire-lookout-among-four-people-killed/
Postby Staryder61 » Tue Aug 09, 2022 3:35 pm
No lightning, so no new fires. Bummer. :?
Knowing and seeing first hand the devastation a fire can do.. your comment here totally takes me by surprise ....
Bummer. :?
You sound like my noobie cadet on his first truck out of the fire house.. "I hope we get a good one". He rolled hose for the next 3 fires..
Thankfully for all those that matter, there weren't any fires...
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby tony.latham » Tue Aug 09, 2022 4:19 pm
I worked wildfires for 15 years. There's not a true firefighter out there that doesn't want the whistle to blow from time to time. Firefighters feed on fire.
:frightened:
Postby JasenC » Tue Aug 09, 2022 6:11 pm
Those aren't to help make it easier for you to slide yourself down the bar to say hi to that pretty gal that just sat down.
I'll be done when I'm finished, if that's not fast enough, take a number.
Build Thread https://www.tnttt.com/viewtopic.php?f=50&t=74269
JasenC
Images: 122
Postby Tom&Shelly » Tue Aug 09, 2022 6:47 pm
tony.latham wrote:The lookout was built in 1947. It's heavily grounded with several runs of 3/8" copper wire. I don't know how many times it's been struck by lightning but in all those years, it's been struck, a lot. We took over from a guy that's been staffing this lookout for 51 years and has been inside when it's been hit several times. When we took over from him last year, the night before the shutter bolts were lit with St. Elmo's fire from the static during a storm.
Okay, that's exactly what I would expect. Of course, my knowledge is from theory. I can easily explain why it's perfectly safe in the tower during a thunder storm, especially after others have demonstrated it is so. If I were the first, I would be concerned there might have been some aspect of the theory I overlooked.
As for the half inch or so of glass insulation between the legs of the wooden chair and the thinly covered metal floor, when the lightning bolt travels several thousand feet through ionized air, what's to prevent it from ionizing that last few inches of air around the glass?
tony.latham wrote:I really want to be inside when it gets struck. (Weird, eh?)
Sounds like an adventure!
"Adventure is the romantic name for trouble." -- Louis L'Amour
But, okay, I think I would be up for that too! :FNP
Incidentally, what I would like to see for such an adventure are good non-corroded bonds between the ceiling, walls, and floor of the inhabited shell on the tower, even the grounding down the tower into the ground wouldn't be as important. (In our friend's hydrogen balloon--that Shelly and I once flew in overnight--that bonding between conducting parts is the primary insurance against any sparks making it a Hindenburg re-enactment.)
Tom&Shelly
Images: 2294
Postby JasenC » Tue Aug 09, 2022 6:59 pm
So which area do you put your bread during a lightening storm for the best results.
Please reference the chart.
169966
JasenC
Images: 122
Postby tony.latham » Tue Aug 09, 2022 7:26 pm
JasenC wrote:So which area do you put your bread during a lightening storm for the best results.
169966
Good one. I do know we're supposed to stay away from the woodstove during storms. :shock:
Postby twisted lines » Wed Aug 10, 2022 8:20 pm
I recommend hearing protection if your hunting lightning strikes, had a close one :o it's loud.
21 lightning fires, Believe this plane guides the big boys for the drop, they're all busy :frightened:
and its windy enough it's clear for now.
Racking up; And Rapin foam
twisted lines
Postby twisted lines » Thu Aug 11, 2022 9:51 pm
Broke a femur :thumbdown:
twisted lines
Postby tony.latham » Thu Aug 11, 2022 11:06 pm
twisted lines wrote:Broke a femur :thumbdown:
Seriously??? :frightened:
Postby JasenC » Thu Aug 11, 2022 11:58 pm
What?!?! :frightened:
JasenC
Images: 122
Postby twisted lines » Fri Aug 12, 2022 8:33 am
X ray girl didn’t think so,
“I guaranty it’s not broke if you can touch it like that”
Yes it is.
twisted lines
Postby twisted lines » Fri Aug 12, 2022 8:40 am
Glad I got a new automatic this week.
Wish I drove it yesterday, the drive home with a clutch was Bad.
twisted lines
Postby nsfr1206 » Sat Aug 13, 2022 5:14 pm
Did you fall off something?
nsfr1206
