I promised to let you know what I thought of the "Son Of Hibachi" grill. Tonight I made some won ton soup for the family dinner. Part of the recipe called for barbequeing marinated pork.
I pulled the grill out of the trailer and lit it up following the manufacturers instructions. (as shown in the video at the top of this post). When I closed the sides together to allow the coals to heat up, I could hear a whoosing sound as air moved up throught the unit like air in a chimney. The coals were fully coated in grey ash in less tha 10 minutes. I was able to start cooking right then cause that sucker was good and hot. The meat was in danger of burning because the grill surface can only be raised about 1 1/4" above the coals. I went inside for a few minutes and when I came back out, the meat was searing maybe a bit more than I wanted. This was a factor of my inattention and not a design flaw with the product. If you didn't want to cook your meal quickly, you would probably need to wait until some of the heat dissapated from the coals. The way it was, I could see that meals are going to be prepared very quickly. You can keep food warm by placing it under the unit. That works very well.
I put the unit into the bag to put out the coals for future use. That works well. Overall, I am quite pleased with this little barbeque. There is no lid for covered cooking (as with a Weber), but for open flame barbequing, this does what the advertising promises it will. And it is small enought for my teardrop. I know most of you folks are committed to making everything with a dutch oven. But if you ever desire something else, this barbeque might help you prepare it. I give it three thumbs up.
