And you can't dislodge the table by knocking it upwards, as you can with the Sailor Sam's type. Not a problem for an outside table perhaps, but definitely a possibility if your knees are wedged under a dining table.exminnesotaboy wrote:I picked up this one - not far enough along in my build to mount and test it, but it looks like it would work fine(and cheap!)
exminnesotaboy wrote:I picked up this one - not far enough along in my build to mount and test it, but it looks like it would work fine(and cheap!):
linky, linky
TonyCooper wrote:I like this style much better! Is it aluminum?
linky, linky
San Diegan wrote:
While we are at it, any sources for a telescoping leg? I would like to make it removeable from the underside of the table and adjustable in height.
