working on fenders
working on fenders
Postby Ron Dickey » Thu Mar 20, 2008 9:53 pm
How far above the tires should the fenders be for those pot holes?
Ron D.
173882......173887
Ron Dickey
Images: 787
Postby ARKPAT » Thu Mar 20, 2008 9:59 pm
Measure the distance from the bottom of your frame and the top part of your spring atachment to the axel and add an inch ( axel tilt fudge factor and mud sticking to tires ). :thinking:
Someone else might have a different way. :thinking:
Pat
ARKPAT
Images: 77
Postby Gage » Thu Mar 20, 2008 10:21 pm
It depends on how stiff your springs are and how much your tear weights. You can most likely get away with the lip of your fender being even with the top of the tire. Chances are because of the weight of your tear, if you hit a pot hole the whole tear will bounce. :thinking:
P.S. On second thought. Your running with itty bitty wheels and most likely H.F. type fenders. So locate the fenders (top of fender) about 3" above the top of the tire. That'll work.
Image Image Image
Gage
Images: 28
Postby Dean_A » Thu Mar 20, 2008 11:45 pm
I think dexter recommends 3".
Dean_A
Images: 55
Postby toypusher » Fri Mar 21, 2008 6:52 am
Dean_A wrote:I think dexter recommends 3".
Would have been my minimum recommendation!
toypusher
Images: 324
