Axel is here
Axel is here
Postby tbow » Fri May 28, 2004 9:00 pm
Its here now, but I'm not sure how to mount it there wasn't any paper work with it and I figured eveyone here could help me with it. So here is my ?'s. first should it be welded to the frame or bolted? next which direction do the arm's point to the front or back? And when mounting it do I use for placement of the axel a distance from the center of the axel or from the center of the hub?
tbow
Postby mikeschn » Sat May 29, 2004 5:56 am
Hey tbow,
Never weld your axle directly to the trailer. What if you have to replace it?
I can only talk about the dexter torsion axle that I have on mine, but I welded the angle brackets to the frame, and bolted the axle to the brackets.
As far as the placement, use the Bill Adkins formula that is available on Larry's outbackteardrop page...
http://www.outbackteardrop.com/chassis.html
It's in the paragraph that starts with the word Axle.
Hope that helps...
Postby mikeschn » Sat May 29, 2004 6:03 am
Oh yes, on Larry's page of afterthoughts he shows some pictures of his axle and shackle.
http://www.outbackteardrop.com/body9.html
That should help you with your axle orientation. I think Larry also has a 2d drawing somewhere on his website, but I can't find it right now.
Postby tbow » Sat May 29, 2004 10:59 am
Thanks Mike I have the same axel I went to dexters site and found the info last night but thanks for the reply
tbow
