by denverd0n » Fri Mar 18, 2005 1:14 pm
So, what do you need to know?
The main thing to be aware of with propane is that it is heavier than air. That means that if there's a leak in the system the gas will flow down and pool at the lowest point that it can. Therefore, you either want a form-fitting airtight box so that very little propane is able to pool, or you want the lowest point to vent out to the atmosphere where it will quickly dissipate.
