Hello everyone. I've got a problem that I'm hoping one of you can help me with. My dad an I are building a teardrop to pull behind my 2001 Miata and when we were planning it out we figured we'd get some wheels to match the car. Seemed like a really good idea at the time so we took into account everything we could. We accounted for the wheel width (6.5-7 inches), size (16), offset (40mm), bold pattern (4x100mm or 4x4inches), travel, clearance, etc. and I ordered the axle.
I pick up the problem and immediately realize I have a problem. The axle is exactly what I ordered but not what I expected. As you all probably know (and I didn't), trailer spindles and hubs are completely different from the ones on cars. So I've got these huge spindles sticking out 4 inches or so from the hub face (as opposed to short caps on the car) and no possible way to put matching wheels over them. In fact, as it turns out, there aren't any wheels with that bolt pattern and size, much less offset, and certainly not design.
So there's my problem. I could exchange the hubs for a different bolt pattern but I can't take back the custom-made torsen axle. So what I'm hoping someone here knows is what bolt pattern do I need to fit wheels that are 16x6.5 or 7 and will accommodate the spindle? And how do I shop for wheels that will fit the spindles? I've seen trailers out there with matching wheels so I know someone can do it, I just don't want to get the wrong thing a second time! (what I'd really like to do is put car spindles and hubs on that axle...). Any suggestions or advice would be welcome. Thanks in advance,
::Digitac
