Mattress thickness
Mattress thickness
Postby Waliczek » Mon Mar 21, 2005 6:58 pm
Hi,
Well the Rimple is done except for the painting of the sides, and I have to wait for some good weather in order to spray. While I wait, I decides to make some kind of decision on my foam mattress. I know it's not brain surgery, and most likely has been discussed several times, but since there is no search feature, I am hoping that one or more of you can recall where and when the thread was discussed. Your opion on thickness is also desireable. I am thinking of 4" firm. Do you think that this is thick enough?
Thanks,
"Toys"--2003 Dodge Dakota--TT Rimple"Gypsy"--1955 Boles Aero Travel Trailer--2002 Sweetwater 20' Pontoon--1982 22' Mcgregor sailboat..
Waliczek
Postby ALAN GEDDES » Mon Mar 21, 2005 7:15 pm
In the Search there are 168 entries for mattress. They are an individual choice and depend on cost, tear size and use/comfort level desired. Air mattresses are not used by many.
Alan
ALAN GEDDES
Images: 34
Postby mikeschn » Mon Mar 21, 2005 7:19 pm
I did a search for Knox Foam, and found 26 matches... but I'm only going to give you 1 to get you started... ;)
http://tnttt.com/viewtopic.php?p=14751
P.S. BTW, I use 4" Grade A medium, and it's perfect for us!!!
Images: 479
Postby Waliczek » Mon Mar 21, 2005 7:57 pm
AW Right, Thats what I'm talking about. Thank you for the links. I cruised the links, and have a good idea what is going to work.
Many Thanks,
Waliczek
