Material Weights
Material Weights
Postby dh » Fri Sep 04, 2009 9:15 pm
I've been looking up and down the sight (MadJack, please hit the search with the BFH again) and do not see a compilation of material weights. I remember the hardware store back home had a chart that listed the aprox weight of the lumber products it sold. They had it for a loading reference, and wouldn't let you haul off more than your truck could handle. I'm trying to get as close of an estimate as I can to the weight of my TD before I build.
Does anybody out there have such a chart?
dh
Postby Ageless » Fri Sep 04, 2009 10:40 pm
Nope
But easy enough to find one
http://www.csgnetwork.com/lumberweight.html
Ageless
Postby S. Heisley » Sat Sep 05, 2009 1:02 am
There used to be one on the forum but I can't find it anymore. For a quick estimate, this chart seems to run pretty true to life:
http://tnttt.com/viewto ... c&start=45
Postby teardrop_focus » Sat Sep 05, 2009 1:40 am
The Kaykraft Kampster, one of the vintage 1936 teardrop builds from steel and 3/4 ply, complete galley, ice box, etc... only weighed a claimed 650 lbs., but that's before your gear. EasyUp folding canopies can weigh over 50 lbs. Water weighs approx 8.34 lbs per gallon...
Another interesting factoid that plywood boatbuilders like to remind us of is that pound for pound, plywood is stronger than steel.
My 4' X 4' X 9' steel and plywood teardrop will weigh under 500 lbs empty, but I will be adding much lightness as part of the build. Adding lightness is quite labor intensive; I expect it to be a lot of work.
:pipe:
teardrop_focus
Images: 127
Postby teardrop_focus » Sat Sep 05, 2009 5:10 pm
Over twelve hours later I can see that perhaps my post ^ wasn't that helpful as it relates to the thread topic's actual question... but it was late, I was tired and I tried.
:lol:
I'd be curious myself to see the differences in weight, say, between 4 X 8 sheets of a 13-layer, 3/4" Baltic birch and some other exterior, quality ply... and the actual differences in weight between fiberglass sheet and .030 aluminum sheet...
teardrop_focus
Images: 127
Postby Ageless » Sat Sep 05, 2009 5:27 pm
Chris; .045 fibreglass which is sold in a roll is 5 oz/sq. ft. ; .032 Aluminum is 7.16 oz/sq.ft.
Ageless
Postby teardrop_focus » Sat Sep 05, 2009 9:04 pm
Ageless
Image!
Thank you... :-)~
teardrop_focus
Images: 127
