b.bodemer wrote:I opted for a breathable weather resistant cover:
camper cover clicky
Then I purchased a silver heavy duty tarp from HF just large enough for the roof and some overlapping on the sides.
Think about sealing any area that might leak with something like a butyl caulk. A product you can easily remove later unlike silicone.
doug hodder wrote: But then it's never windy in No. Colo right?
Doug
Like previously mentioned get a good tarp. I don't think I'd use one of those cheap blue ones....they are notorious leakers and are cheap for a reason. I'd also get out and clean off the snow that piles up on it.
48Rob wrote:It seems to me that if we as old trailer hobbiests are willing to spend so much time, money, and effort in fixing these trailer up, we should also be willing to spend a little money to either have the repairs made so weather isn't an issue, or pay to put the trailer in a dry garage until time can be found...
The old trailer hobby is expensive, just part of the game.
With that said, the following may be of some use.
I'm not a fan of tarps, as they can trap moisture and cause even more damage.
If the trailer is covered from top to bottom, it can't breathe, and general humidity can work on it, unseen, all winter.
Damp rid may be the solution to that problem.
The other issue with tarps is that while it is easy to plan in the nice weather about how we'll go out in the nastiest weather of the year to check on the condition of the tarp...it usually doesn't happen.
When the snow piles up, then melts a little, and refreezes, how to you "brush it off"?
The answer is you don't.
You must wait for it to melt.
The problem occurrs when there is an unseen hole in the tarp, and the melted water under the ice and snow gains entry to the roof, where it then seeps into the leaky roof, and continues to rot the trailer while you're snug and happy in your home thinking "gee, that tarp sure is saving my little trailer".
Come spring, you discover that it is beyond repair...happens a lot...
I'm sure many people will say that they've used tarps for years with no problems, and they may be right, or lucky, or their roof didn't leak in the first place.
Not too many come on and report that their great idea of using a tarp failed, and they ruined the trailer...likely because they're so sick about it that they just junk the trailer and move on to other hobbies "because those darn trailers are just leaky piles of junk".
Temporary caulk may help a little, if you can determine where the leak(s) are. Often, a roof will leak a good distance away from where the stain shows up.
A practical and easy remedy to limit water damage during the winter is to park and set up the trailer so the roof is not flat.
The faster water can run off, the less time it has to pond and seep into the framing.
After choosing the parking place, lay a few boards on one side so that when you back the trailer in, the tire will be parked on the boards, wich will tilt the roof from side to side.
Then, crank the hitch either all the way up, or down, to be as unlevel as you can get it.
Either way you go, if you can leave the door uncovered for easy access so you can inspect the interior for damp and or wet spots, it is much less risky than sealing it up tight and just hoping it will be fine till spring.
Rob
