Factory doors for my teradrop
Postby Chuckles2153 » Mon Apr 05, 2010 9:27 pm
I hate to keep asking questions but last week i saw a posting on some factory made tinted glass doors someone sells but i can't find that post now :x
I really like the look of them and want to buy a couple of em for my build so can someone please point me in the right ( or left ) direction ?
I also hear that grant? sells very needed parts to complete a build so could someone tell me how to get in touch with him also ?
PLEASE, PLEASE, PLEASE :worship: :worship:
Chuckles2153
Images: 74
Postby Miriam C. » Tue Apr 06, 2010 7:49 am
Grants site
Lil' Bear Tag-Alongs: (530) 242-6452
Jan 25, 2010 ... Li'l Bear Teardrop Hinges, Moldings & Seals. hinge. "Better-Than-Hurricane" Leakproof Galley Lid Hinge. 2-piece Extruded Aluminum - mill ...
www.lilbear.teardrops.net/parts.html - Cached - Similar
:) Just google! There were some others on Ebay but you will need to look them up. Also try our "For Sale" section. :thumbsup:
Postby absolutsnwbrdr » Tue Apr 06, 2010 7:51 am
Is this the door you're thinking of?
I got 2 from a member on here (cks-1), but they can also be found on ebay.
I think its technically called a drop-down feed window, as used in horse trailers and such.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Thamks for the info.
Postby Chuckles2153 » Tue Apr 06, 2010 8:34 am
Miriam C. wrote:Grants site
Thank you Aunti M. I just put that website into my favorites and will certianly be ordering from him i hope in the very near future. :D
Chuckles2153
Images: 74
Postby Chuckles2153 » Tue Apr 06, 2010 8:42 am
absolutsnwbrdr wrote:Is this the door you're thinking of?
Those r exactly what i'm wanting to get for my TD. :bowdown: You r the man!!!
I'm in your debt Zach. Chuck
Chuckles2153
Images: 74
Postby absolutsnwbrdr » Tue Apr 06, 2010 1:10 pm
Glad I could help! They're a bit pricey, but I think they're worth it. I don't have mine installed yet, but very soon!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby jonnyo » Fri Oct 28, 2011 4:40 pm
I want to purchase this exact model, but wondering if there is a side to those door or if you can simply turn them upside down to make it left or right? any problem with this?
I need a odd size....20X30 to fit between the studs of my aluminum trailer... and wonder if i can simply order 2 drop-down feed door and simply put one upside down so i get a curbside and roadside? anything against it? leak? etc?
thank you!
jonnyo
Postby Mukilteo » Fri Oct 28, 2011 9:49 pm
They make a seperate door for each side.
Eric
Mukilteo
Images: 18
Postby jonnyo » Fri Oct 28, 2011 11:04 pm
would you mind to elaborate? what is different from one side to the other from flipping the door upside down?
is there and orientation where the door will leak in rain? something i would really like to know
thanks!
jonnyo
Postby DezPrado » Sat Oct 29, 2011 6:23 am
I converted one of these right hand opening doors to a left hand opener last summer. (the supplier only had right-handers in stock & sold me the second one cheaply because his stock wasn't moving). Anyway moving on.... there are drain holes in the bottom that need to be filled, and new ones created when the door is inverted. I also discovered the glass window, top I think, was not cut symmetrical & wouldn't fit properly so a new one was made. In addition the exterior seal strips were not able to be reused either, becuase of the corner cuts & sizing/lengths now being different . The change-over took a bit of work to acheive the desired result but it is acheivable with perseverance. I'm happy with mine & it don't leak!!
Remember though, you might get a door that is perfectly symetrical so your mod process will be marginally different. Good luck
DezPrado
