I want something that is like foamcore board. But instead of paper on each face, I want luan or some other lightweight (1/8") wood panel. In the middle I want something like styrofoam that is light and easy to cut with a jigsaw. This product must be without voids and be easy to paint. It must come in 4 x 8' sheets, be 3/4" thick and cost no more than $40.00 a sheet.
So, DOES ANYBODY MAKE A COMPOSITE PANEL PRODUCT LIKE I AM DESCRIBING?
halfpastsix wrote:Plastic Soffit...
It weighs nothing, is strong, waterproof, easy to cut and cheap. I don't know how good it would be for making theatre sets, but for a camper it's perfect. If I were to do it again, I would forget about the wood framing and just glue it together, it is that strong.
How did you finish the edges on this. I have been thinking of using it for my new build.
bdosborn wrote:Make your own lightweight panels. Its simpler than you think:
Plastic from HD, packing tape, and a shop vac.
aggie79 wrote:I haven't used it, but our local plywood specialty company has Foamkore panels made by Kerfcore. They only stock 4' x 8' x 3/4" with hardboard faces, and it sells for $61/sheet. Kerfcore is available with poplar faces too.
Here is a link to the product:
http://www.kerfkore.com/NEW%20BROCHURES/foamkore.pdf
Users browsing this forum: Bing [Bot] and 11 guests
