Solar system
Someone on teardrop times had set up a really nice solar system with electronic digital readouts that showed the status.
Does anyone have a link to that system?
mikeschn wrote:Okay, I found what I thought I was looking for.
http://www.retroteardrop.com/project/build/galley1.php#
Except now I don't think he has solar????? At least it's not shown on his wiring diagram.
I guess I'll have to design a teardrop system on my own.![]()
[/quote]Mike,
I'm not too surprised by the fact that they don't carry the lower voltage modules any longer. Using a higher voltage module like the SM55 along with a regulator is more efficient and adds very little complexity to the system. All you're doing is attaching the 2 wires from the module to the controller (regulator) then attaching the 2 wires from the regulator to the battery. Rest assured that the folks at Backwoods will never steer you wrong.
QHey Q,
I got this message back from your friendly folks at backwoodssolar...
Hello Mike We no longer carry self-regulating modules but we can provide a module and separate controller which will accomplish the same thing. We have a $315.00 Shell SM55 watt module which can be effectively regulated by a $33.00 Sunguard controller. Scott
So how much complexity does this add to the system? Should I be looking for the same unit as you have? Please advise.
Shadow Catcher wrote:Bruce actually has his solar system up and running, mine is still in boxes waiting to go on the trailer. http://tnttt.com/viewtopic.php?t=11275
