by eamarquardt » Tue Jan 18, 2011 5:18 pm
I have an older Delta disk/belt sander missing a guard. Went to an aluminum foundry today to see about having a replacement cast (a friend has a guard I can use as a pattern). Was quoted less than a hundred bucks for two of em. The price was a bit high as the guard is thin and will/may be difficult to get a good mold.
Maybe you could find one to use as a pattern and have a few cast. Bear in mind the new ones will be approximately 1.5% smaller than the original.
Could probably have "waffle dog cookers" made also if anyone had a good pattern and there is enough interest.
Gus
