trolley top
trolley top
Postby droid_ca » Mon Feb 14, 2011 12:10 am
I'm thinking a trolley top for my design might be best but evert time I draw it out it looks likeImage so I was wondering what the percentage is or is it just a wing it sort of thing pitures would really help thanks
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Trolley top
Postby danlott » Mon Feb 14, 2011 1:12 am
Don't have a hard and fast rule for a trolley top. I think 6 to 8 inches high would be best. Also if you plan on installing windows in the trolley top then you need to consider how you are going to construct the windows. I used google sketchup to design my trolley top. I was able to draw it several different ways before I settled on my final design.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby emiller » Mon Feb 14, 2011 4:12 pm
I think Craig's nephew built a trolley top teardrop.
emiller
Images: 157
Postby Mightydog » Mon Feb 14, 2011 9:55 pm
emiller wrote:Craig
I've read his list a couple of times!
Hey danlott! Don't forget to post pictures of that great stove/oven when you build your galley!
Mightydog
Postby danlott » Mon Feb 14, 2011 10:13 pm
Mightydog wrote:Hey danlott! Don't forget to post pictures of that great stove/oven when you build your galley!
I will make sure to include pictures of the stove in my build thread when I get to that point. Probably be a little while though at the rate I am going. By the way, thanks again for helping out with that.
Dan
danlott
Images: 264
Postby DMcCam » Mon Feb 14, 2011 10:14 pm
Doug Hodder has done a few beeeeauties. He's a great guy and gives incredibly valuable guidance. Here's a link:
http://www.mikenchell.com/forums/album_personal.php?user_id=454&sort_method=pic_time&sort_order=DESC&start=252
You might try the search in the top line of the masthead area too.
Best, Dave
DMcCam
Postby doug hodder » Thu Feb 17, 2011 8:32 pm
I do it all old school....paper, scale, triangles and a french curve. Just draw up something to scale that has good curb appeal to you so that the top doesn't look like it's tacked on as an afterthought. At least that's my approach.
I also insulate the tops, although not as much as the rest of the roof. You need to remember that the inside won't be as large as it appears on the exterior with insulation, important when wanting to install any portholes or windows in it. Allow enough lift to fit any openings and still allow some material around them. The aft end of a trolley top is a great place to hide a fantastic fan. Just what I've found. Doug
Postby droid_ca » Sat Feb 19, 2011 12:39 am
thanks very much the american voyager is on of my favorites
“Fide Canem”
droid_ca
Images: 176
Postby Rigsby » Sat Feb 19, 2011 5:32 pm
Jackdaw built one a couple of years ago, and he is starting with his second now. here is a link to his second build
http://tnttt.com/viewtopic.php?t=42298
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Postby sdakotadoug » Sun Feb 20, 2011 2:09 pm
I always wondered if a trolly top would not be a good place to semihide an air conditioner, but I'm just a noob, what do I know. Hey Doug is that feasable or not. And now back to the regularly scheduled thread, Doug
sdakotadoug
