Ready for some good answers.
goramsey wrote:How would one go about getting a replacement for this old puppy?
down under tech wrote:goramsey: I would still replace the thermocouple. It's job is to tell your burner control valve that the pilot light is lit. This way gas will only flow to the burner if the thermocouple tells it it "feels" the heat from the pilot light. It is a safety precaution to keep any gas from being pumped into your cabin that is not burned and that gas could kill you. It could be very bad if you strike a match or a spark from a light switch. You might have to re-light the pilot light over and over if you keep using the old nearly worn out thermocouple. Just replace it now so you will be done with it.
It is not that hard to change and not much money either.
