Shower tent
Shower tent
Postby Justin & Katy » Mon Feb 21, 2011 1:45 pm
I know this is a subject that has come up several times but i'm looking for a shower tent. Does anyone have one that they really like? Any I should stay away from?
Justin & Katy
Images: 81
Postby Big Dan » Mon Feb 21, 2011 2:17 pm
Yep this one has been covered. It kind of breaks down like this. The small ones are less money and set up quicker and the bigger tents have more room and hold up better in wind.<< In a nut shell (very small nut shell) :chicken:
"Happiness is only real when shared" Alexander Supertramp
Big Dan
Postby nevadatear » Mon Feb 21, 2011 3:02 pm
yup, thats about it. I love my outback porta privy from www.beprepared.com. It has stood up well for two years, but I don't leave it up in the wind to take any chances, but it is simple to set up and take down, once you get the hang of it. And was pretty cheap at $66.
nevadatear
Images: 171
Postby Big Dan » Mon Feb 21, 2011 3:19 pm
One thing I forgot to mention. If you're going to use the tent for a bathroom. You might want to get one you can tie down so you can leave it up over night if its windy
Big Dan
Postby Miriam C. » Mon Feb 21, 2011 3:29 pm
Be careful to get one that is vented at the top. Some of the cheap, hunting type pop-ups can get very hot fast!
This one seems to work well and reflects some of the heat. Don't know about shadows... :NC
Postby sid » Mon Feb 21, 2011 4:21 pm
We like this one from Northwest Territory. The double wide with the extra changing room is worth a few extra dollars.... it keeps your clothes dry and makes it handier for two people to shower at the same time... :thumbsup:
Just google... Northwest Territory 3.5 x 7 ft. Double Shower and Changing Room
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby youandi » Sun Mar 06, 2011 2:52 pm
We use the same tent for the shower & toilet.
"The farther one gets into the wilderness, the greater is the attraction of its lonely freedom." Theodore Roosevelt
youandi
Postby rowerwet » Mon Apr 11, 2011 6:17 am
we got one from Wallyworld to use during the tub replacement in our house last summer, It is beefy and worked fine, ended up leaving it up all summer as a changing room for the pool. It will support a filled solar shower fine, just make sure it is secured with the side ropes.
http://www.walmart.com/ip/Ozark-Trail-M ... om/4726169
rowerwet
Images: 521
Postby mary and bob » Mon Apr 11, 2011 6:33 am
We have one from Cabelas, I think it's about 4 X 4 feet, we use it as a changing room. Got it on sale a couple years ago, little less than $100 maybe. Bob
mary and bob
Postby pete42 » Mon Apr 11, 2011 7:44 am
Sid said "two people to shower at the same time... :thumbsup: "
now that's what I like to hear saveing water is commendable. ;)
pete
pete42
Postby Pottercounty » Mon Apr 11, 2011 7:48 am
Bought one from Target, "Ozark Mountain" shower/toliet tent. 4 strong steel poles, attaches easily, has rain fly, plastic reinforced floor with venting & weep holes for water to escape. Has stood up fine in a torrential downpour & winds. Very roomy...Same as Rowerwet's above...
Paid $35
best, Tim
Those are my principles. If you don't like them I have others.
Groucho Marx (1890-1977)
Pottercounty
Images: 20
Postby Shadow Catcher » Mon Apr 11, 2011 7:52 am
We have not decided for certain but like the PahaQue http://www.pahaque.com/Merchant2/mercha ... Code=tepee
Postby aggie79 » Mon Apr 11, 2011 9:21 am
We have the side tent from Camp Inn. (Please excuse the poor picture of it.)
Pros:
-attaches to the teardrop
-solves the "where to put shoes question"
-allows teardrop door to be open for more air circulation
-large enough to use as a change room and potty room
-well made
Cons:
-expensive
-smaller and shorter than some
-won't fit some teardrops
-have to buy your own Texas A&M string lights for it
Take care,
Postby CliffinGA » Mon Apr 11, 2011 7:56 pm
We have the 2 room Northwestern and works good for the porta potty but when we tried to use the solar shower the top ring broke and hit me in the back while showering. What we do now is just leave the porta potty in the ez-up and at night put the walls up.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby the other side » Mon Apr 11, 2011 9:20 pm
I have the 2 room Northern Territory and I can't see how we could make it without it!!! We use one side for potty, showering and a water bowl for a basin, and the other side for dressing and storing our clothes.
We haven't battled any wind worth speaking of when we used it. Easy to set up (I set it up alone).
I'm trying to find an easy to set up tent with side walls option that can be up or down (once again that I can set up alone) to cover from the vent fan and the kitchen area.
the other side
Images: 10
