Roof sealer over plywood?
Postby MushCreek » Sun Mar 06, 2011 3:15 pm
I haven't been here in a looonnng time! Many things have changed; I never did build a teardrop, but I am working on another trailer project. This one is down-n-dirty; I need a weatherproof box on wheels to move my stuff when we move to SC. I started with an old frame, and added on here and there, turning it into a 7X10 flatbed. Plans are to build a box on it and waterproof it. I am putting a 'vee' on the front, and also sloping the roof down to make it slightly more aerodynamic than a brick.
Here's the question: Has anyone 'painted' a trailer enclosure with a roof sealer like Kool Roof? I'm building the box out of cheap plywood sheathing, and am gluing the framing to make it sturdy. I want to get at least a couple years out of it, at which time I might sell it, turn it into a camper, or remove the box and build a proper teardrop on it. I figured that rubbery white roof coating would protect the cheap plywood better than paint would for a couple years.
In retrospect, I probably should have just bought a used enclosed utility trailer, but that wouldn't suit my DIY mindset, and it would have cost me considerably more money. I just wondered if anyone had tried that stuff on a trailer. Looks are unimportant! Due to the size of the trailer, I don't want to use fiberglass because of the cost. Thanks for any input!
"An optimist is a man with two acorns and a hammock."
Jay
MushCreek
Postby kirkman » Sun Mar 06, 2011 3:28 pm
I have used this http://www.koolseal.com/product_detail.asp?product_id=63-300 On a utility trailer just like you are building it is still working great after 4 years!
kirkman
Images: 55
Postby Ptomaine » Sun Mar 06, 2011 4:02 pm
On my first build, an ultra low cost Weekender, I used a elastomeric roof coating to paint the whole thing. The hatch, door, and one of the seams leaked like a sieve, but the coating held up fine. When I chopped up the camper after 4 years, the plywood was still like new. I did a recoat after 2 years because it was looking a little dirty. Rolling on a new coat was easier than trying to clean it.
As you grow up and leave the playground where you kissed your prince and found your frog.
Remember the Jester that showed you tears The script for tears.
Ptomaine
Postby MushCreek » Sun Mar 06, 2011 4:30 pm
Well, that's good to know! As a one-time boat builder, the box will be waterproof without any coating, but I wanted to protect the cheap plywood from the elements. Do you know if you can paint over that stuff? Ya never know, I might want to dress it up a bit with a contrasting stripe or something.
Jay
MushCreek
Postby Deryk the Pirate » Sun Mar 06, 2011 5:00 pm
could use some fiberglass cloth and epoxy and do the edges then put the roofing stuff over the whole box.
Deryk the Pirate
Images: 158
Postby kirkman » Mon Mar 07, 2011 6:40 pm
Yes you can paint it! I have a stripe on mine to break it up. :thumbsup:
kirkman
Images: 55
Postby MushCreek » Mon Mar 07, 2011 7:14 pm
Cool! Now that we have a plan, all I have to do is build it! I think I will glass the seams; the transition where the angles comes together would be a good spot for a leak to develop. Who knows- If it's not completely dreadful, I might even post a few pics......
Jay
MushCreek
Postby kirkman » Tue Mar 08, 2011 1:50 pm
That's what I did. I fiberglass taped all the seams and so far no leaks.
kirkman
Images: 55
