Fiberglass
Fiberglass
Postby fbaly » Sun Mar 06, 2011 10:28 pm
Alright crew one more questions for you all.
I just put the top of the teardrop together.
I was told by a trusted friend that I should probably look into putting fiber glass on the front bend of the trailer for protection.
He also said it would help water tight the teardrop.
Opinions?
Also, a guide for getting that stuff to work...
Does fiberglass just stick to wood?
Thanks
Fred
fbaly
Postby Dale M. » Sun Mar 06, 2011 10:36 pm
Fiberglass won't stick to anything, the resin that holds fiberglass will stick to the wood.....
Fiberglass can be a good solution, but understand the surface you are putting it on has to be prepped to decent shape and if you are not really good at application, it will take hours of sanding and grinding to get smooth finish, quite frankly there is more important thing to do with your time..... I would consider some prefinished "sheet" products and just glue it on before I would go the glass/mat & resin option...
And its messy.... You will have to mask off every surface on TD you do not want contaminated with drips and spills.... If you have never worked with resin and cloth this in not the "scale" of project you want to learn on....
Dale
Dale M.
Images: 18
Postby S. Heisley » Sun Mar 06, 2011 10:40 pm
I'm really sorry I used fiberglass tape. It seems to be impossible to get a smooth finish with it. Too late now, anyway. The paint is on and I'm not going back and redoing it. :(
Postby bohemian » Sun Mar 06, 2011 10:52 pm
Fiberglass can be a beautiful thing.
Go to the West systems web site read up on the application of epoxy resin and you will do fine. :thumbsup:
Say away from polyester resin for wood. It doesn't stick to it for long. :thumbdown:
WayneImage
bohemian
Images: 233
Postby SonofT@B » Mon Mar 07, 2011 6:16 am
bohemian wrote:Fiberglass can be a beautiful thing.
WayneImage
Wayne it IS a beautiful thing. I have admired your work for a long time...beautiful piece of craftsmanship!
BTW where did you get the exterior door stop/latch...been looking for something like that?
Mike and Jackie in Atlanta
T@Bitha (2004 T@B)
Ford Ranger XLT 2003
SonofT@B
Postby Steve_Cox » Mon Mar 07, 2011 7:00 am
Fred,
Using Fiberglass cloth, tape and resin is a skill that you have to learn. It can beautiful only when the skill levels have been developed. I suggest watching many You Tube and material supplier videos. Also read everything you can get your hands on about the application processes. Over the years I have done quite a bit of epoxy and fiberglass cloth over wood, my results still leave a lot to be desired. But my work is a whole lot better than that first project.
Steve_Cox
Images: 196
Postby pete42 » Mon Mar 07, 2011 8:31 am
Fred like others have said it can be a messy process but it can turn out great.
I built a two person all fiberglass airplane back many years ago.
if you start a lay-up you have to finish it no comming back tommorow to add another layer.
maybe your question should have been what do others do to cover the front of the trailer.
pete
pete42
