Paint - Epoxy question
Postby terryjones1 » Mon Mar 21, 2011 9:07 am
I am building a TTT using 3/4" x 1" framing and 1/4" plywood inside and out. I have used epoxy as the glue.
My question is with covering the outside plywood walls.
I used 1-1/2" fiberglass tape and epoxy on the seams. I am now going to cover the outside wall with epoxy, while the wall is laying down flat.
See below:
After applying the epoxy on the outside wall, I can either sand and paint the outside wall, while it is laying down, or wait until the walls are installed on the trailer.
If I paint now, I am concerned with epoxy "running" down the side walls when I apply 3" fiberglass tape & epoxy to the edge of roof and top of side wall.
If I paint after installing the 3" fiberglass tape, I am concerned with paint "running" while wall is in verticle position. I will be using Pettit Easy Poxy Paint, applying it with a "roller".
I want take the approach that is the easiest of the two. I am leaning towards painting when walls are installed!
Anyone have experience applying Pettit Easy Poxy Paint, while wall is verticle?
My TTT Garageable Standy Build Journal: viewtopic.php?f=50&t=40591
terryjones1
Postby starleen2 » Mon Mar 21, 2011 9:17 am
I painted mine while it was "up" and now wished i had done some prepainting while the walls were laying flat - Thin paints tend to run a bit and I ended up having to sand a few of them out on the first coat. You can probably get away with a first "color" coat while it is flat - however please note that if you plan on sealing the edges where the walls meet - you'll have leave an area unpainted so the epoxy can stick to epoxy - not just a layer of paint :thinking:
starleen2
5th Teardrop Club
Postby terryjones1 » Mon Mar 21, 2011 9:25 am
starleen2 wrote:I painted mine while it was "up" and now wished i had done some prepainting while the walls were laying flat - Thin paints tend to run a bit and I ended up having to sand a few of them out on the first coat. You can probably get away with a first "color" coat while it is flat - however please note that if you plan on sealing the edges where the walls meet - you'll have leave an area unpainted so the epoxy can stick to epoxy - not just a layer of paint :thinking:
Thanks for your input!
I have planned on "masking" the edges.
Would "running" paint be better or worse than "running" epoxy?
terryjones1
Postby planovet » Mon Mar 21, 2011 9:29 am
I painted mine while it was flat. It was MUCH easier this way and there were no runs to worry about. :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby GPW » Mon Mar 21, 2011 9:31 am
TJ, flat is nice and everything will "settle" ... Runs are just something that needs to be sanded out, paint or epoxy ! More work !!!! :o
