by Corwin C » Tue Mar 22, 2011 9:16 pm
I'm missing where you want to apply the force. Is this for hatch struts or force on the hinge or ???
On this type of calculation all of your vertical forces times the horizontal distance from a common reference point HAVE TO SUM UP TO ZERO if it remains stationary. Keep track of your positives and negatives in both force and distance for this to work (upward positive, downward negative etc.)
Just from your diagram, if it takes 40 lb (upward) to hold the hatch stationary, and the hatch weighs 70 lb (downward), then the hinge is applying a force of 30 lb (upward) to balance everything.
Now some assumptions ... (all the engineers are collectively shaking their heads and saying "shame, shame")
If the 40 lb force applied to the hatch is lets say 50" horizontally from the hinge you can find the center of gravity of the hatch in that position by using algebra (if you move the hatch you will need to re-calculate because the horizontal distance will change). I'm going to use the hinge as my reference point.
(Force at hinge times distance from hinge) plus (force at end of hatch times distance from hinge) plus (force (weight) of hatch times center of gravity distance from hinge) equals ZERO.
(30lbs * 0") + (40lbs * 50") + (-70lbs * x") = 0
Solve for x (I had a professor in college that would write "ATAMH" on the board ... And Then A Miracle Happens)
x = (40 * 50) / 70
Meaning that the center of gravity of the hatch in this position is about 28.57" from the hinge.
If you apply other forces (say a pneumatic hatch strut), then you have to include them in your calculation. I know that this doesn't answer your question, but hopefully it will jog your memory or at the very least help you give us the information we need to find the number you are looking for.
Corwin C on Tue Mar 22, 2011 9:54 pm, edited 2 times in total.
Corwin
and no one should be expected to accept anything less. -- myself
