radius Question
radius Question
Postby JeepThing » Tue Mar 29, 2011 8:17 pm
OK this might be a dumb question but here goes.... How do you measure a 20` radius? is there a simple method or do I just use a framing square. How to? What is the formula? (me not so good in school :lol: )
Tact is for people who aren’t witty enough to use sarcasm
JeepThing
Images: 73
Postby GuitarPhotog » Tue Mar 29, 2011 8:28 pm
Do you mean 20 inches, or 20 ft?
20 inches can be done with a yardstick, a nail and a pencil. 20 feet usually requires a tape measure, a string, and a pencil.
Is that what you're asking?
<Chas>
GuitarPhotog
Images: 55
Postby Miriam C. » Tue Mar 29, 2011 9:53 pm
:thumbsup: Measure in 20" and 20" down or up, depending on where the curve is. Make a mark and use any 20" stick to draw the curve. :thumbsup:
Oh and yes a framing square to find it will work too. ;)
Postby planovet » Wed Mar 30, 2011 8:35 am
A nail, a string (or stick) and a pencil :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby chorizon » Wed Mar 30, 2011 11:43 am
I measure radii at work with a Coordinate Measuring Machine.
If I wanted to draw a certain size radius I'd use one of the aforementioned techniques.;)
chorizon
Images: 94
Postby planovet » Wed Mar 30, 2011 2:30 pm
chorizon wrote:I measure radii at work with a Coordinate Measuring Machine.
Show off :lol:
ImageMark (& Cindi)
planovet
The Cat Man
Postby JeepThing » Wed Mar 30, 2011 3:00 pm
Thanks, what i'm trying to figure out is degree of radius, like a 20 degree 30, 15 and so on. Is there a formula i missed in school or forgot? is 20" down and 20" in and draw a line with pencil and string from that point make a 20 degree radius? what would it be if i went 20" down and say 15" in what would that make it? Questions that make me go Hmmmm?
PS i only have a carpenter's square, pencil and small lenght of string, will try an borrow a calculator. So the CNC won't be of much help LOL :thinking:
JeepThing
Images: 73
Postby Miriam C. » Wed Mar 30, 2011 6:04 pm
Can you give us a picture of what you are trying to draw! If it is the Generic Benroy, Mike did a better description that is now a sticky. If you are looking for an ellipse then try this:
http://www.angib.pwp.blueyonder.co.uk/t ... tear80.htm
Postby JeepThing » Wed Mar 30, 2011 11:44 pm
It will be a basic benroy design , like the plan calls for; the short compass will have a 19" radius and the long a 48' radius, I'm just not sure how to get that?
JeepThing
Images: 73
Postby Miriam C. » Thu Mar 31, 2011 8:42 am
:thumbsup: :applause: http://tnttt.com/viewtopic.php?t=43208
This makes it so much clearer!
Postby JeepThing » Thu Mar 31, 2011 11:53 am
Thanks, I think I got it, So a 19 degree radius would be measured 19" down & 19" in; the circle made from that point would have a 19 degree radius? Correct?
JeepThing
Images: 73
Postby Miriam C. » Thu Mar 31, 2011 12:07 pm
:thumbsup: That is correct and on the Benroy you need to start the 19" point in and 18 5/32" up then have it meet the 48" curve (actually started from the bottom corner in 41.5625" and up 48")
Postby doug hodder » Thu Mar 31, 2011 8:30 pm
I'm not so high tech....I got a long piece of 1/8" ply 3/4" wide....I shape it the way I want till it looks good. Stick in a couple of nails to clamp the thin ply to. Drag a pencil and voila...a profile. No flat spots or tangents to contend with. Doug
Postby bobhenry » Fri Apr 01, 2011 10:17 am
OH SLOW !
You were using the wrong compass again !
:lol: :lol: :lol:
Postby Dean in Eureka, CA » Fri Apr 01, 2011 11:48 am
JT,
This link will show you how to layout an ellipse, courtesy of Andrew...
One of best pieces of information regarding profile layout IMO.
http://www.angib.pwp.blueyonder.co.uk/teardrop/tear80.htm
Dean in Eureka, CA
The Fogcrawler
Images: 69
Users browsing this forum: Bing [Bot] and 15 guests
