pop up
pop up
Postby Boanerges4 » Wed Apr 06, 2011 7:28 pm
Found a popup today that I can purchase for 75.00. Just wondering how big of a tire can I put on the hub, once I tear it down. I would much rather run a 13 0r 14. Thanks :roll:
Boanerges4
Postby absolutsnwbrdr » Wed Apr 06, 2011 8:04 pm
As long as the new wheels match the bolt pattern on the hub you could essentially get whatever size you want. When rebuilding the trailer just make sure you have clearance between the tires and your trailer.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Dusty82 » Wed Apr 06, 2011 9:11 pm
What absolutsnwbrdr said.
Here's a link to a bolt circle template you can download and print to check the bolt circle on the pop-up.
http://www.easternmarine.com/em_store/t ... ircle.html
A great majority of pop-ups came with Dexter axles (either tube or torsion type) so parts are pretty easy to find. If you think you'll need brakes, Dexter sells brake kits for almost every axle they've made, so that's a plus if it doesn't already have brakes on it. Look for an aluminum tag wrapped around the axle tube - that'll have the axle part number and serial number on it, which comes in VERY handy when looking for bearings and seals.
TV: 2004 Jeep Liberty Sport
Currently stuck in a tent.
Dusty82
Users browsing this forum: Google [Bot] and 10 guests
