Wild Bill wrote:Just watched several you tube videos trying to find one to recommend and did not see one that mentioned to inspect the spindle for pits or cracks, hub for damage, inspect the bearing races or drums for cracks, Springs, hangers, u bolts etc. One guy even said with the wheel on that 1/4 inch of "play" was acceptable!! None showed pitted or dark metal (heat Damage) bearings so that you will know what a bad one looks like. I recommend that you have someone who knows what they are doing walk you thru the process the first time. The unknown factor is that persons level of knowledge and experience. I have found u-bolts on trailers, missing or rusted or broken, cracked hanger welds, broken springs and cracked spindles, while repacking bearings, A good experienced mechanic will inspect all of this and know what to look for. One site said every 20k miles. A long time to wait in my opinion. Most do it yourself people can do this job. This should be demonstrated at a large gathering. It would be as popular as a dutch oven cooking demo!! Bill
Wild Bill wrote: cannot get the rear bearing out without damage to the hub seal.
