Old frame...can't find serial number
Postby Woodstramp » Tue May 31, 2011 11:11 am
Got another old camper frame that is sound and would like you use it on another project in the future....can't find a serial number. Is there a common location where serials are stamped on the frame? Thanks.
Woodstramp
Postby caseydog » Tue May 31, 2011 11:53 am
On my old trailer frame, the serial number was on a decal -- not stamped into the steel. I photographed it, then sanded it off and painted over it.
It is possible that your frame had a serial number decal or plate that is now gone.
CD
My build journal is HERE
caseydog
Images: 515
Postby Deryk the Pirate » Tue May 31, 2011 12:11 pm
Clean it up and fix it up and call it a homemade trailer if you cant find it.
Deryk the Pirate
Images: 158
Postby Aaron Coffee » Tue May 31, 2011 5:04 pm
Seems like the serial number on the old pop-up I used to have was on a sticker on the inside of the door, never checked to see if there was also a number on the frame or not.
Aaron Coffee
Images: 26
Number
Postby Wild Bill » Tue May 31, 2011 5:14 pm
Do you have a picture of the camper or the make and model or is it just a frame that is already stripped? Jayco had a decal on the square part of the frame left front corner on the outside frame rail. Depends on the make and a lot of them were only silver decals that are long gone or if stamped were filled with paint years ago. Good luck Bill
Beavers are Naughty!
Wild Bill
Images: 63
Postby Micro469 » Wed Jun 01, 2011 10:03 pm
Why do you guys need a serial # on an old trailer??? Would'nt that just be used for the original use? What happens if you don't have it...does that mean you can't use the frame?
John
Micro469
Images: 382
Postby Corwin C » Fri Jun 03, 2011 8:41 am
Some locations require chain of ownership. VIN/serial numbers make the process easy...
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Users browsing this forum: Google [Bot] and 8 guests
