Porta Potty
Porta Potty
Postby Boanerges4 » Sat Jun 25, 2011 2:09 pm
What do most campers recommend when it comes to Porta Potty? What features should I be looking for? Camping world has an RV marine 2.6 gallon that looks good, but Im new at this camping thing. Also they will ship for 5 dollars. Someone please sound of and let me know. Thanks :thinking:
Boanerges4
Postby CliffinGA » Sat Jun 25, 2011 2:45 pm
Well go by your nearest Walmart and look in the rv section they had a Thetford brand that we paid 70 for last year on clearance for 35. As long as the wife is happy then I'm happy. I get by with a five gallon bucket.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby depatty » Sat Jun 25, 2011 2:58 pm
5 gal bucket and bag of kitty litter or sawdust here. 8) :lol:
depatty
Images: 175
Postby pete42 » Sat Jun 25, 2011 5:12 pm
any camping store or some of the "mart" stores have some be sure to get one you can use some are too small.
I have found using a porta-potty other than number 1 is best left to the women.
I have one I found that it sits to low and I built a sturdy box/platform for it to sit on raising it to a usable level.
mine probably holds 2-3 gallons of water and waste
some things I do like about a porta-potty is you don't have to move the whole trailer to a dump station during an extended stay
just take the part that empties.
pete42
Postby Wolfscout » Sat Jun 25, 2011 7:30 pm
portapotty on a home made stand. or a 5 gallon bucket with toilet seat adaptor. very handy. Especially at night or when traveling and there's no restroom spot for another 50 miles. :oops:
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Boanerges4 » Sat Jun 25, 2011 9:22 pm
Just came from WallyWorld. They have the Thetford for 69 bucks and the coleman for 68. Anyboby out there have an opinion on which one is the best? :lol:
Boanerges4
Postby CliffinGA » Sat Jun 25, 2011 11:10 pm
LOL about the same! Too bad your not closer to GA, then could get ya cheaper one!
Cliff
My Build:
CliffinGA
Images: 207
Postby kirkman » Sun Jun 26, 2011 7:20 am
The Thetford seams to be the one most people have. You should really consider the 5 gal. bucket with 2 tall kitchen trash bags and kitty liter method. It works like a charm and there is no cleaning you just toss it! :thumbsup:
kirkman
Images: 55
Postby Helixpteron » Sun Jun 26, 2011 4:26 pm
The Porta Potti 335 will fit virtually anywhere, yet has a useful capacity.
Light and compact enough to be moved easily, too.
Helixpteron
Postby the other side » Tue Jun 28, 2011 8:42 am
We have the Thetford have had absolutely no complaints. After 5 days and nights of camping the thing still wasn't full, no odors, no leaks, and I dumped it in a sewer hole that the travel trailers and 5th wheels etc use for their sewage. It has an "arm" pipe thing of PVC/plastic inside it that you pivot and dump the sewage out through (we put TP in a bag). I took a hose and squirted it out clean, put it back in its box and that was that. I think it is a 5 gal. Not too heavy to carry when full. Mine has a "pump action" flushing thing. The flush honestly cleans the bowl each time (I do 2 pumps). I don't think I would like it if it didn't flush!!! If there was anything weird or wrong my daughter wouldn't use it, and she is just fine with it too.
the other side
Images: 10
Postby Trackstriper » Tue Jun 28, 2011 6:58 pm
Porta-Potti review....
I've got about ten years total time with portable flush toilets, have one in my work van. Used on a regular, year round basis. They generally seem to be good for about three to four years regular use then the seals start getting a little wonky and it's just easier to buy a new one than try to fix the old. The seals aren't really replaceable like those of an RV toilet. Started with a Thetford, currently use a Dometic.
The Thetford's plastic seems a little softer...has a little more give to it. The seat generally feels a little larger to the tush than the Dometic. However, I cracked the lid on the Thetford (not the seat), it was located in my small shower compartment but didn't hold up to the sit-down use, perhaps the lid itself was never designed for the weight of a whole body. The Thetford had a bellows type pump and did work well, I could modulate the flow of water ...relatively decent flush.
The Dometic had a more substantial plastic, a slightly smaller seat, and a manual pump air-pressurized flush system. The pump always worked well, but the flush was mediocre. It couldn't be modulated and didn't seem to be aimed well to clean the bowl very well. I am now on my second Dometic, and the flush is the same as the first unit....mediocre. No problems with the lid on either unit for sit-down use.
For my cargo converson I did pick up a Thetford 465 electric flush unit...thought the wife might find it more convenient....but in initial "dry" testing it looked like it would use a lot of water per flush. I'm a little dubious about the flush on this unit, I think I would add some sort of flush wand run from the trailer water system to get the job done with the least volume of flush water...that's the key. Haven't tried it out in the "real world" yet so I will hold firm opinions 'til later.
As some others have noted, if you get a unit that has little capacity it may be a little low to the ground and uncomfortable to get up from or to sit upon. :roll: :roll:
Trackstriper
Images: 38
Postby mikeschn » Tue Jun 28, 2011 7:04 pm
Trackstriper wrote:As some others have noted, if you get a unit that has little capacity it may be a little low to the ground and uncomfortable to get up from or to sit upon. :roll: :roll:
Of course there's a time when a smaller unit is exactly what you want...
In this case for example. the lower unit, combined with the dropped floor is perfect. :roll: :thumbsup: :lol:
Postby Trackstriper » Tue Jun 28, 2011 7:47 pm
Yes Sir, that would be correct! Ya gotta figure where your feet are. Of course, if you had a deep enough dropped floor you could put a bucket under the trailer and use just a seat and cover lid...ala the ole' outhouse.
Sorry, just heard too many tales of folks who had a hard time gettin' up from the potti....I'm still limber enough so it's not a problem but I do like not having to dump (edit..the potti) as often. If you're going for just a weekend it's probably no biggie. I may be at a job site for a week and the capacity sometimes comes in handy.
Trackstriper
Images: 38
Postby Pottercounty » Tue Jun 28, 2011 8:39 pm
5 gal. bucket topped with the "Luggable Loo" seat, add kitty litter & TP you're good to go..
best, Tim
Those are my principles. If you don't like them I have others.
Groucho Marx (1890-1977)
Pottercounty
Images: 20
Postby cathymb » Wed Jun 29, 2011 3:38 am
[quote="Trackstriper"]Porta-Potti review....
I use a sport drink bottle (with the squirt cap) to flush. Less water and better aim .
cathymb
Palladium Donating Member
