Jack Wheel
Jack Wheel
Postby the other side » Thu Jul 21, 2011 2:28 pm
I'm looking for a removable jack wheel with the caster assembly that is made to roll in gravel or sand. My daughter has a wheelchair that you can order specialty wheels (like if you want to take the wheelchair on the beach). Has anyone seen any specialty wheels for the jack on the tongue of a trailer/camper?
the other side
Images: 10
Postby glenpinpat » Thu Jul 21, 2011 3:17 pm
tsc sells them
glenpinpat
Postby the other side » Thu Jul 21, 2011 4:01 pm
I still don't see it, or am I looking in the wrong place. The one wheel they list doesn't say anything specific. It is being sold for 19.99. The other one is 29.99 but that is a bolt on and neither mention anything about being different from all the others (the common ones).
the other side
Images: 10
Postby glenpinpat » Thu Jul 21, 2011 4:18 pm
no you are not looking in the wrong place I did not read original posting properly. :? croft trailer supply sells a pneumatic tire assembly that slips under your jack but the use 2 wheels.
glenpinpat
Postby Mukilteo » Thu Jul 21, 2011 6:22 pm
I think Slowcowboy's idea is great. I wonder if HF has the same castor that locks. ie a brake.
I bought the HF trailer dolly for moving my trailer around in the dirt.
http://www.harborfreight.com/heavy-duty-trailer-dolly-37510.html
Eric
Mukilteo
Images: 18
Postby the other side » Thu Jul 21, 2011 11:05 pm
I did see some castor wheels with breaks, but none of them looked as big. I would have to find someone that can weld it for me though. But I do REALLY like the brake idea! I was going to get a dolly but I figured it would be more convenient to just have a good pair of wheels instead of a wheel and a dolly.
glenpinpat that's just what I was thinking about! I'm gonna get that. Thanks for finding it for me. I can't find that ANYWHERE else.
Meineke fixed the wheelchair tires tons of times before they figured out I was doing 16 stairs atleast 2 times a day and pinching the tire/tube. Expensive lesson learned and a major inconvenience too (no chair till it was fixed and repeated trips to meineke). But the teardrop will NOT be going down stairs... just through the thick gravel in my driveway!
Thanks load you all!!! The convenience of having it delivered and ready to use will be worth the money. Wait till you see these on my little tiny tear! I'm sure they will look HUGE!!! :lol: But they will be functional and easier I assume!
the other side
Images: 10
Postby the other side » Fri Jul 22, 2011 10:57 am
I called Croft today. They actually designed (I guess and make) this jack wheel kit. The lady told me they have been making them since last year. They are the only ones I can find that have this design. I wonder why no one else has put this out? To me it is a logical/common sense solution, and easier to carry with you (compared to a dolly, which would be my second choice).
the other side
Images: 10
Postby Mukilteo » Fri Jul 22, 2011 5:59 pm
Got a picture of it?
Eric
Mukilteo
Images: 18
Postby Gage » Fri Jul 22, 2011 6:39 pm
Here's one offered by the Teardrop Fix-it-Shop. $49.95
Image Teardrop Fix-it-Shop
Image Image Image
Gage
Images: 28
Postby Mukilteo » Fri Jul 22, 2011 7:27 pm
Thanks
Eric
Mukilteo
Images: 18
Postby the other side » Sun Jul 24, 2011 8:05 am
Is that $49.95 or $81.00 from Teardrop Fix-it-Shop?
the other side
Images: 10
Postby Gage » Sun Jul 24, 2011 2:28 pm
the other side wrote:Is that $49.95 or $81.00 from Teardrop Fix-it-Shop?
My bad :o They're $81.00 each. Sorry about that. It's an age thing. :?
Image Image Image
Gage
Images: 28
Postby the other side » Sun Jul 24, 2011 4:11 pm
And here I was PRAYING you were right!!! On the other hand, I though it was an aging thing for me too !!!
the other side
Images: 10
Postby the other side » Tue Jul 26, 2011 3:02 pm
I figured out the Croft wheel does not pivot. The guy at Croft was very helpful and told me how I could get my jack to turn instead (by removing a nipple on the jack where there is a ridge running down the length). My husband doesn't like that idea, so now all I have to do it find someone that can weld the pipe piece on the caster like slowcowboy did. :roll: I thought this was going to be an easy purchase and wait for it in the mail.
the other side
Images: 10
