ok i`m back after a long absence,i hurt my back ,but here i am again,starting a new build....question?i am having problems figuring out how to cut the area for the rear hatch....i just cant grasp it...maybe in simple terms i will......thank you for your help and its great to be back...
Welcome back! If you are still using the same sides it is easier to do this before you install them. Page 20 of the Generic Benroy plans has a good description with pictures. You will find it easier if you dry fit your sides and spars making sure to get them square and mark them. Then you will know where your last spar lands.
fast freddy wrote:thank you so much,i can build but some things i just cant get to stick in my brain!
Several times I would built a test piece out of something cheap to make sure I got the desired results. And I did not always get it on the first try either.....
