Deb wrote:We bought a heated mattress pad, with dual controls of course, for our TD. My question is will I have issues with our one inch memory foam topper? Do I need to put the mattress pad over or under the topper? Has anyone used a heated mattress pad? Hope you can help!Thank you!
droid_ca wrote:silly question ....Do you keep them turned on all night or just long enough to heat up the bed and whats the battery drain like?
nevadatear wrote:
Also no problems with battery drain, and we have a single battery. But we do turn it off after we are nice and warm, don't generally leave it on all night.
Debbie
wincrasher wrote:would you recommend a heated mattress pad over a small ceramic heater?
or should you have both on hand?
