I do have a list of criteria however,
Needs to be very light as it will be towed by a small van
No need for separate rear galley
Will need the provision for an awning on door side
I'm only short (5'6") so it doesn't need to be long.
I thought I'd put Idea no.1 to all of you and hopefully we pick any holes in the idea together.
My idea is not to build a regular teardrop shape but instead using a
6'X4' 6" base and being no higher than 4'6" from the ground I would like to create in miniature one of these
Placing the wheel near the back like so
and utilising the classic 13 panel ends like so
The idea is to build as close to scale as possible.
Using three "hoops (one supporting each end panel join and one in the centre of the middle panel also acting as part of the door frame) the front and rear panels will use the "folds" for strength.
I was thinking of using a "wool" type of insulation with a removable fabric linning.
Am I a genius?, or is this the dumbest Idea a man ever had (if you think the latter I can provide pages and pages of my other ideas as evidence to the contrary).
All comments welcome good and bad.
Thanks, Mark.
