Need some opinions
Need some opinions
Postby oregonguy » Mon Oct 03, 2011 7:54 pm
Hey everybody. I need some opinions on whether or not you like a cosmetic touch that my brother and I are thinking of for our "Streeter" model teardrop.
It will certainly be optional to order either way...but we're trying to decide whether to equip this first model with the "Accent Bars" pictured below. They'll be mounted with 3M commercial grade sticky tape, so they'll be removable if necessary. I also put up a pick showing the trailer without... The question is, do you like the cosmetic "Accent Bars"?
With
Without
If you want to see full detail build pics, click here: http://www.oregontrailer.net/Oregon_Trailer/Streeter_Build.html
Thanks in advance for your input. :)
Check out our Website: www.oregontrailer.net
oregonguy
Images: 48
Postby Pottercounty » Mon Oct 03, 2011 7:57 pm
Looks good actually,....go for it. As you said, it peels off so why not?
best, Tim
Those are my principles. If you don't like them I have others.
Groucho Marx (1890-1977)
Pottercounty
Images: 20
Postby Shadow Catcher » Mon Oct 03, 2011 8:02 pm
One other possibility, custom graphics. The bars seem a bit simplistic and well, drab. But then, truth beauty and contact lenses are in the eye of the beholder.
Postby canned o minimum » Mon Oct 03, 2011 8:02 pm
Looks fabulous... I always like to break up a dull canvas.. so to speak.
canned o minimum
Postby Maureenm » Mon Oct 03, 2011 8:03 pm
I vote for....adds a little touch.
Maureenm
Postby Moho » Mon Oct 03, 2011 8:06 pm
Much nicer with the accents
Moho
Images: 69
Postby stumphugger » Mon Oct 03, 2011 8:11 pm
I prefer flames... :)
stumphugger
Images: 76
Postby CARS » Mon Oct 03, 2011 8:15 pm
I love them. :thumbsup:
Chris'
Autobody
Restoration
Service
CARS
Postby Oldragbaggers » Mon Oct 03, 2011 8:30 pm
I definitely like them.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby eamarquardt » Mon Oct 03, 2011 8:32 pm
I like em. Not overdone. I also like changes that can be reversed.
Gus
eamarquardt
Images: 150
Postby tk » Mon Oct 03, 2011 8:45 pm
You sure the tape is removable? I worked with one 3M tape that almost certainly would cause you to tear up the substrate before ever getting the tape removed.
Best,
Escape to Missouri
tk
Postby oregonguy » Mon Oct 03, 2011 8:53 pm
tk wrote:You sure the tape is removable? I worked with one 3M tape that almost certainly would cause you to tear up the substrate before ever getting the tape removed.
Best,
A little acetone will dissolve the adhesive and leave aluminum untouched in my experience.
oregonguy
Images: 48
Postby Verna » Mon Oct 03, 2011 9:00 pm
I'd keep them. Without them, the side of the TD looks sort of "blah". With them, it separates your TD from so many silver aluminum TD's.
Verna
Verna
Indianapolis, IN
Verna
Images: 49
Postby BrwBier » Mon Oct 03, 2011 9:19 pm
Looks good, keep em
Brwbier
BrwBier
Images: 100
Postby starleen2 » Mon Oct 03, 2011 9:20 pm
They suck! :R Just thought I'd bust the comment streak. They look pretty darn good! :thumbsup:
starleen2
5th Teardrop Club
