Outline
Outline
Postby ALAN GEDDES » Fri Apr 16, 2004 3:11 pm
How to draw an elipse. If you want curves that are not perfectly round try this: Make a model first out of a 6 inch stick and then scale up to the size you want. Put a nail at both ends. tie a string about 15 inches long to make a loop. put the loop around both nails. hold pencil inside string and keeping tension on the string and holding wood in place draw an oval. rotate the board a few degrees and you start creating the roofline of a Tear. Adust lengths/angles to get what you want. AL G
Alan
ALAN GEDDES
Images: 34
Excellent site.
Postby Larry Messaros » Sat Apr 17, 2004 12:43 am
If you want more info on elipses check out this site. I can't remember his name but I believe he is in the UK. There is also a lot more teardrop info on his site. It's well worth checking out.
http://www.angib.pwp.blueyonder.co.uk/t ... tear00.htm
Larry Messaros
:snow
Cariboo Country: If you don't like the weather, wait 5 minutes!
Larry Messaros
