New here so forgive me if this isn't the proper place to pose this question.
I had done a search for soft-sided and canvas covered teardrops. I found a couple of discussions but I didn't find where anybody had actually completed one.
So, my general thought is about the idea of doing the entire skin of a teardrop in canvas as a means of keeping the weight down.
In the discussions I've seen, two questions seemed to pop up.
1. How would it hold up to being pulled down a highway.
2. How to waterproof it if it's not bonded to wood (luan, etc.).
The first question I can't really answer. It would seem logical that it would depend on how strong the skelleton of the teardrop is, but I'm sure most of you have enough experience to know if that thinking is correct or not.
With respect to waterproofing, I've taken what I know of regular tents and what I've read about TTTs and it seems to me that if you're using canvas (vs. nylon) that the biggest issue with respect to leaking would be the roof. Good canvas should have a tight enough weave that this shouldn't be a big issue on the vertical surfaces. At least, that's true of the canvas tents I've used.
To that end, I did a search for something that I didn't find any hits on. But, has anybody used or considered using Flex Seal as a coating for canvas?
I'm sure that most of us have seen the commercials for this product by now. The salesman removes the bottom of a boat, mounts a screen door sprayed with Flex Seal in it's place and the boat doesn't sink?
For those who may not be from the states or haven't seen it for whatever reason, it's essentially a spray on rubber coating that resists extreme heat and extreme cold. Remains flexible and doesn't crack.
From the few reviews I've read online about the product, it actually works fairly well (though I doubt anybody has been crazy enough to actually try the boat trick to see if it works).
So, my thought would be to coat the roof and perhaps the seems with that.
From what I've read, the large can weighs about 14 oz and covers about 12 square feet, depending on how thick you make it. So, enough of it to cover the roof of a 4x8 teardrop (trying to account for the curves and such) should add maybe 5-6 pounds to the total weight. Still, less than a wood skin would weigh.
Anybody used it? Thoughts for and against?
TJ
