Comparing a Weekender and a Cubby
Postby Benhamtroll » Thu Jan 12, 2012 12:38 am
I'm trying to decide which design to go with for my first build. Cost is going to be an issue, with a new baby on the way in May. I have just about every woodworking tool imaginable, but no welding skills (hence my two choices).
Is there a significant cost savings between either of these designs, all things being equal?
Benhamtroll
Postby Deryk the Pirate » Thu Jan 12, 2012 1:34 am
Id build a 5 foot wide weekender with a shelf/bunk for the baby.
deryk
Deryk the Pirate
Images: 158
Postby Benhamtroll » Thu Jan 12, 2012 1:37 am
Interesting idea! I had been thinking of D-clips on the ceiling and a hammock, but a baby-bunk is kind of snazzy, too!
Benhamtroll
Postby Deryk the Pirate » Thu Jan 12, 2012 10:25 am
This way if you build it in from the start you will get a few more years out of it when the little one gets larger.
Deryk the Pirate
Images: 158
Re: Comparing a Weekender and a Cubby
Postby rowerwet » Tue Apr 03, 2012 5:58 pm
the little one will most likely cause time to be the enemy (says the guy with 4 kids) the weekender is meant to be a quicker build.
rowerwet
Images: 521
Postby mikeschn » Tue Apr 03, 2012 6:01 pm
The cubby is really small, and a lot of work, like the guys mentioned.
The weekender, with it's flat panels is designed to be a fast and easy build.
Also check out the weekender II design, which is a design in progress, here: viewtopic.php?p=921223#p921223
Postby wagondude » Tue Apr 03, 2012 7:39 pm
So, if the Weekender in designed to be built in a weekend, is the Weekender II designed to be built in a weekend er two? :shock: :R :lol: :lol: :lol:
Sorry, couldn't resist
Bill
Bill
101137
wagondude
Images: 35
Postby S. Heisley » Tue Apr 03, 2012 9:44 pm
The weekender would be the quickest and the most versatile for your needs. :yes:
Postby absolutsnwbrdr » Wed Apr 04, 2012 8:05 am
wagondude wrote:So, if the Weekender in designed to be built in a weekend, is the Weekender II designed to be built in a weekend er two? :shock: :R :lol: :lol: :lol:
Well played :lol:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Kharn » Wed Apr 04, 2012 10:52 am
Weekender all the way, the 8' Cubby has the cabin cabinets too close to the door so you can't have a meaningful bunk without losing the cabinets entirely. The 10' Weekender can still have a few cabinets while allowing sufficient space for a bunk.
I forget who it was, but one member has photos in his gallery of how he made a bunk for his kid. He used ~1" wood dowels with wall fittings (solid circles on one wall, lift-out U-shapes on the other) and heavy fabric looped over each dowel and sewn. It should be more comfortable than just a shelf, plus since the middle will be lower than the dowels, it isnt as easy for the kid to roll out and down onto you. That should work until the kid is old enough to sleep in a tent next to the trailer.
I would include a third set of dowel fittings next to the fittings at the rear of the cabin, allowing you to stow the assembly with the fabric rolled around the two dowels and have more usable space during the day or while towing.
Kharn
