Michigan DMV question
Postby LashleyT » Thu Jan 26, 2012 7:48 am
I just finished building a HF trailer and need to get it registered in Michigan. My question is about weight, can I use the kit's shipping weight to register it or do I need to have it weighed at a truck stop or camper store to register at the DMV? :thinking:
LashleyT
Postby bobhenry » Thu Jan 26, 2012 7:50 am
The certificate of origin given to you at the time of purchase should be all you need.
Postby pete42 » Thu Jan 26, 2012 8:38 am
In Ohio the trailer has to be weighed any grain elevator will do it for a small price.
I would weigh it before building anything on it.
which is what I did years ago
pete42
Postby absolutsnwbrdr » Thu Jan 26, 2012 10:02 am
Check your state laws. PA requires you to get the assembled trailer weighed and then inspected. I got my first trailer weighed after putting a plywood deck on, and the inspector questioned why the weight on the shipping slip was different from the measured weight. That ~60lb plywood sheet was the difference and the inspector OK'd it.
I'm skipping all that B.S. this time, and registering my new trailer in Maine as a non-resident. No inspections, no weighing. Just a few pieces of paperwork and a check for $10.50 8)
EDIT:: Found this in another forum. Sounds easy in MI
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby jandmz » Thu Jan 26, 2012 7:52 pm
Down "south of the border" (Ohio) our DMV accepted the stated capacity on the MSO (Manufacturer's Statement of Origin) that came with the trailer paperwork. My wife used the MSO at the Registrar's office, and they issued the plate and registration with nothing else needed. The trailer was still in pieces on the garage floor when she came home with the plate.
jandmz
Postby Ptomaine » Thu Jan 26, 2012 10:22 pm
Each state likes to mess with your head with silly licensing rules. California was really easy. Drive it to the DMV sop they could check the serial number.
Wisconsin probably has the easiest. Under 3000 lbs = no registration required = no fees!
As you grow up and leave the playground where you kissed your prince and found your frog.
Remember the Jester that showed you tears The script for tears.
Ptomaine
