What is a true weekender?
Postby les45 » Wed Mar 14, 2012 4:06 pm
I've been calling my recently started project a "modified weekender". Not sure why, but I figured my personal design aspects made it "modified". I've noticed that many other weekender builders call their projects "modified weekenders" also. Is there a true weekender design or is it just a generic term for an angular type of teardrop? Inquiring minds want to know.
Larry S.
les45
Images: 605
Re: What is a true weekender?
Postby mikeschn » Wed Mar 14, 2012 6:18 pm
les45 wrote:I've been calling my recently started project a "modified weekender". Not sure why, but I figured my personal design aspects made it "modified". I've noticed that many other weekender builders call their projects "modified weekenders" also. Is there a true weekender design or is it just a generic term for an angular type of teardrop? Inquiring minds want to know.
Larry S.
Well, I guess I designed the original weekender. You can see the plans here... http://mikenchell.com/weekender/
But since it's so easy to modify, I guess everyone is modifying it, and doing it their own way! :? :D
P.S. In fact, I am thinking of modifying it myself... :oops:
Postby Gage » Wed Mar 14, 2012 7:33 pm
mikeschn wrote:
les45 wrote:Is there a true weekender design or is it just a generic term for an angular type of teardrop? Inquiring minds want to know.
Larry S.
Therefor I would say a TRUE WEEKENDER is one that is build just like the plans say to build it . :yes:
That was the question, wasn't it? What is a true weekender?
Image Image Image
Gage
Images: 28
Postby mckenney56 » Sat Mar 17, 2012 11:34 am
I thought the "Weekender" name meant if you got all the parts and supplies ahead of time, you could complete it in one or two weekends with limited tools and skills. But, I've seen weekenders on here that took 2 years to build.
What I would like is to modify my weekends to be 2 years. Anybody got any plans for that? Mine is buy a lottery ticket every time I fill up the car, but so far my weekends will have to stay the length they are.
mckenney56
Images: 129
Postby Ron Dickey » Sat Mar 17, 2012 8:27 pm
:thinking: hmmmm memories.
You kinda are right and wrong. If you have the basic tools and understand the basic skills, done the research, looked at ones that had been built already,and have pre bought your supplies; it can be done in a wkend. When I started I had skills, I did not pre plan, it all came out of my head as I watched others build, went to trailer gatherings, listened to people talk who had been there and done that. I have seen the Maxitear, a double axel boat port windows, went to my first gathering up in Northern California slept in a tent. Where I met Dean, Doug, a pioneer Grant Whip, I think even Martha was there too, and saw trailers that had been built by both women and men. Then I was ready to start. But I let everything get in my way. and I had no Trailer frame to put it on it almost became a truck camper. 5 years it took me. Mike did not believe it could take that long and almost kicked me off, till other pointed out that it can take that long.
Now I could build one in a wkend. But first I need to find a set of wheels to put it on. Doors are my week point and Mike pointed out that you can buy the doors, just cut out the place and drill them in. The boxkite had the famous Gun Ports, One hangs in Deans fire house. they were made out of one sided framed plywood and only one side had the gun port the other had no window at all. Piano hinges with outside padlocks kept them closed. I Pulled it all the way to New Mexico that way and it was not until several years later that Steve B. Pulled out his table saw and showed me how to make one. Hanging a door is yet another skill all together.
Tools needed saber saw (I used a dremel with a wall cutting bit) a power drill, Wayne across the street gave me a air compressor (WWII vintage from an aircraft carrier) I got a staple gun from Harbor Freight 60 mile to the south, Got my plywood and 1x2 frame sticks from HD (before I worked there) Set down my floor, attached a 2x4 frame to it painted tar on it, flipped it over framed out the unit like I would a house, drew out the side walls on one side pc, clamped the other to it and cut them both at the same time. With a dremel! all the frame parts were glued together and stapled and then I put glue on the out side and stapled the walls to the ribs. attached sticks to keep the sides up and apart. figured out where my wires would go for the lights sound and set new sticks in to sandwich junction boxes too. Steve B. gave me some strong wood for my cross overhead bars holding up the roof. attached on the roof, cut insolation Styrofoam in between all the ribs and frame. Then put on the inside walls starting with the roof, then the walls.
Now 1. take pictures of every thing you do. you may what to know where the wires are, or if you are drilling what you are drilling into.
2. if you can find anyone that is doing a build near you even if it is a hundred miles away go help or observe it will help. Touching, seeing, and helping makes all the difference. It was not until Steve B. had a gathering just over the hill from me that I found who had a Teardrop near me. John Goes to my Church. So talk it up you may have find the guy next doors father built one in WWII.
I did not have the trailer wheels and frame until I was a Wayne's moms and there sat a boat trailer that hat sat there for 10 years. I had to grind, paint, and put on new wheels, tires, and build a frame on it. it was just a T trailer no front support.
Trailer frame, wood, wires, plan and replan and replan, tools, and free time.
I am now looking at maybe building a second even if the one I have is not done. And it is rear when you find one finished. You see what another did and you know that has to change.
But all in all it is the fun of doing it. The Learning, and going to the gatherings that makes it all the perfect project.
Now I can do mine in a week, if I do not let anything get in the way.
Good Luck
You will want to attach the floor to the trailer frame before putting on the walls. Steve B. started his (which is how I know that part).
173882......173887
Ron Dickey
Images: 787
