I will be taking my 2 neices 9 and 12 and my nephew 10, on a trip to the black hills of South Dakota. I will be taking my teardrop which will sleep 2, I had thought of taking my tent for the other 2, but got thinking that it can get kind of cool overnight out that way, so I may put some sort of sleeping mats in the back of the pickup (it has a topper). My thinking is that it would require less setup(how much help would I get putting up the tent out of 3 preteens after a five hour drive?), be a little more insulated than a tent as the box is double wall so there would be a little bit of dead air space, does any one agree or disagree? Should I consider additional insulation? If so any recomendations on cheap easy to install insulation? I may see if I can hit electric blankets or electric mattress pads on clearance. The topper has sliding screened windows so ventilation should not be a problem. I am also thinking of putting a piece of plywood down with possibly a chunk of carpet on it, then either a single mattress(45" between wheel wells)or some sort of cushions,should I space the plywood off of the floor with 1x2 to offer additional air space? Any other comments, suggestions?
Thanks
Aaron
