Help installing wheel hub caps
Postby ioan » Wed Apr 25, 2012 11:35 am
I tried everything, no luck.
(Are they called "wheel hub caps"? The cap that covers the hub so dirt doesn't get into the bearings)
I have the teardrop on the top of the harborfreight trailer. Yesterday I had the second attempt to install the wheel hub caps and I can't get them in.
Do I need a special tool? I just tried to get them in position and then tap with a mallet, but they are very stubborn, don't want to get in.
Help?
Thanks,
-ioan
ioan
Re: Help installing wheel hub caps
Postby eamarquardt » Wed Apr 25, 2012 12:12 pm
Hi,
You need an SST (Special Service Tool). Get a piece of steel pipe or tubing that will slip over the dust cap and contact the rim of the dust cap. You just need a few inches of the tubing or pipe.
Then use the pipe as a driver to drive the dust cap in. Using the pipe will allow you hammer the cap in w/o ruining it.
Hope this helps.
Gus
eamarquardt
Images: 150
Postby nrody » Wed Apr 25, 2012 1:03 pm
If you visit the etrailer website and search the video's they have one on repacking wheel bearings. They use a small pvc pipe and you can watch exactly how to install the bearing caps. Visual aids help me alot. ;)
nrody
Nancy
nrody
