Started a New Trailer 6/30/12
Postby len19070 » Wed Jul 11, 2012 5:42 am
My son and I started a new trailer the other week. We had some time, some parts, were looking for a project and with the excessive heat here in the North East,Image
it was a good time to go into the shop....so.
The trailer will be up for sale in a few weeks. It takes a standard twin mattress is 9' long, has an Air Conditioner, torsion axle and as the progress goes on pictures will follow. (We're faster than the camera person...the galley is almost done).
till then
Happy Trails
Len
len19070
Images: 24
Re: Started a New Trailer 6/30/12
Postby Oldragbaggers » Wed Jul 11, 2012 7:27 am
You did all this in a few weeks?? Amazing!! Very nice looking trailer.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby len19070 » Wed Jul 11, 2012 9:36 am
Thanks Becky.
It was/is a great Father-Son project and a good place to hide during the HEAT!
Just a few updated photos taken this morning.
Some of the galley and the Doors...waiting for parts!
I was asked if this was a 48" wide Trailer. It is not! It is built to take a Standard, NOT Custom Twin Mattress. Standard sheets, a better mattress for less money. Just like at home.
Happy Trails
Len
len19070
Images: 24
Postby M C Toyer » Wed Jul 11, 2012 10:50 am
Len -
I looks like you used the 24" wide aluminum then added the ribs for the siding. How is it attached? How did you handle the horizontal joints? What is on the roof?
M C
M C Toyer
Images: 11
Postby len19070 » Wed Jul 11, 2012 3:09 pm
len19070
Images: 24
Postby Al in PA » Wed Jul 11, 2012 6:05 pm
Len, what a great tutorial! Two questions: (1) Did you use a solid piece of aluminum for the roof or will the same "Z" joint used on the sides provide a waterproof joint on the roof? (2) Do you have any pictures showing how you joined the corners/applied molding to create a waterproof seal?
Al in PA
Postby len19070 » Wed Jul 11, 2012 7:27 pm
Al in PA wrote:Len, what a great tutorial! Two questions: (1) Did you use a solid piece of aluminum for the roof or will the same "Z" joint used on the sides provide a waterproof joint on the roof? (2) Do you have any pictures showing how you joined the corners/applied molding to create a waterproof seal?
Thanks Al.
I use a rubber roof (I don't trust "Z" joints on a roof...nor do I trust overlap seams either) and run the fabric over the side, then put an RV insert molding set in putty tape over the corner. Then trim the rubber so it goes over the siding.
I'll look for some photos.
BTW, I don't use RV EPDM rubber, I use the commercial grade available at any "GOOD" Roofing supply house. RV EPDM is 20 mills and the commercial, though its the same stuff is 40, and if you can get it 60 mills.
Happy Trails
Len
len19070
Images: 24
Postby len19070 » Wed Jul 11, 2012 7:45 pm
Found a few of a "Mini Shasta" I built a few years ago. Click on any photo to see the entire album build.
Happy Trails
Len
len19070
Images: 24
Postby Al in PA » Thu Jul 12, 2012 8:45 am
Len, thanks for the information and pictures. The pictures really helped clarify the process.
Thanks,
Al
Al in PA
Postby len19070 » Fri Jul 20, 2012 3:22 pm
A few updated photos...I'm much faster than the camera man.
Only a few more days to completion then She's up for Sale.
Still waiting for some parts...The Heat and Humidity has been almost unbearable. 4 days in a row over 100 degrees....and the rest in the upper 90's
We move on.
Happy Trails
Len
len19070
Images: 24
Re: Started a New Trailer 6/30/12 FOR SALE!
Postby len19070 » Tue Jul 31, 2012 1:36 am
Well its a Month since I started.
Still haven't gotten my windows yet (ordered them June 20th)
Tried out a new corner Molding...didn't like it. I'm going back to the standard RV insert Molding.
But with the exception of that, the windows and a few small details, I'm essentially done.
Once the windows come in It'll be going on Ebay...asking $4000.
Happy Trails
Len
len19070
Images: 24
