look what followed me home...
Postby rowerwet » Sat Aug 25, 2012 8:18 am
free! just had to get one tire back on the bead, since it had been abandoned behind a muffler and brake shop they had a tire machine also, while the sidewalls are checked and weathered they worked to get it home. Last night the slave labor crew helped me strip it to the frame. 9724497243
the cap and assorted scrap inside has added nicely to my scrap metal pile, which will follow me to the scrap yard soon...
rowerwet
Images: 521
Re: look what followed me home...
Postby wagondude » Sat Aug 25, 2012 10:24 am
That's a nice pile of recycling that someone left for you. It's hard to believe that anyone would just abandon that much money while others are stealing AC units and wiring. That should give a nice boost to the build budget.
Bill
101137
wagondude
Images: 35
Postby rebapuck » Sat Aug 25, 2012 10:36 am
What sort of plans for it do you have floating around your head non-stop?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby rowerwet » Sat Aug 25, 2012 7:06 pm
the former manager of the shop got the trailer delivered there by a scrap yard, he hack sawed the top off and then let it sit. then he was fired, and it sat over a year that way. the other stuff I'm not sure where it came from, but I'm not complaining. the assistant manager is my next door neighbor... gave him an old but still working air conditioner that I didn't need anymore
rowerwet
Images: 521
Postby working on it » Sat Aug 25, 2012 7:58 pm
That topper looks to have two usable crank-out side windows...don't scrap them, they may help your build or someone else's later. I am still kicking myself for trading away my old '75 Chevy pickup, and the topper mounted on it. The guy wanted to leave it with me, he didn't want it, but my wife didn't want it laying around here either. A year later, I started my TTT build, and wished I had the topper (with windows, screen, associated hardware) laying around. I would've used it for sure. I'm thinking of making my own now, with extra added delay to completion, but would've designed the old topper windows into my plans from the start,if I had kept them.
173193172890148599
working on it
Images: 457
Postby rowerwet » Sat Aug 25, 2012 8:49 pm
I thought of that as I rolled it onto the scrap pile, while I like the idea, I would have to tint them for privacy/heat, and I like round cornered windows, not square, on a td. I would let them go to some one willing to pick them up... my next build will have wiley windows.
my td build in my mind will be "the long, long td" from my designs album97294, this trailer will donate it's nice torsion axle to it...
if I can get 5 lug hubs for it easily. I also love the design of the tongue jack,9729297291 never seen one like it before.
rowerwet
Images: 521
Postby rowerwet » Sun Aug 26, 2012 5:28 am
while stripping the outer skin off i was wondering if I could find similar to skin a td, the skin is very thin, (.025"?) with a dimpled pattern, and glued directly to the 1/4" plywood skin underneath, unlike heavier sheet aluminum this stuff appears to take care of heat/cold movement with the textured pattern. The glue was still very stuck even though the trailer was built in the mid 80's. thanks to it's year or more outside topless all of the wood was rotten which made it easy to tear apart 9727797278 in just a few hours, the hardest part turned out to be ripping the osb deck off the frame. even though the corners and edges were rotten it took the back of my axe head to punch through and make the pieces smaller so I could rip them off with a spade.
rowerwet
Images: 521
Postby rowerwet » Sun Aug 26, 2012 4:44 pm
some parts of this will absolutely end up in my td 97276
I see the sink clipped onto the side of storm warning near the galley, the ice box looked good until I saw how the cheap plastic door was broken at the hinge, and that there is very little foam around the plastic 97275
there is also a power center, I'm gonna have to check out how it operates to see if it is worth putting in my td 97280
along with some 12v lights that I can put LED's in and use inside Storm Warning.
but this frame is going under this 97274
the utility box that was on the trailer Storm Warning rides on again, as soon as I give it a shave with my sawz-all
rowerwet
Images: 521
Postby rebapuck » Mon Aug 27, 2012 2:20 pm
That tongue jack is just like the one on my european Puck. Over there it's called a jockey wheel.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby rowerwet » Mon Aug 27, 2012 3:52 pm
I love the way it can slide up and down to take up the slack, then after you tighten it, you use the regular style screw to raise the load.
rowerwet
Images: 521
Postby rowerwet » Mon Aug 27, 2012 7:10 pm
found this tag inside a door, 1992 meteorite gvwr 1430, the axle is rated at 1600 minus tires and wheels, I almost swapped the TS trailer back to cargo duty and put this under the td, but that would require way to much modification to storm warning to be worth it now.
I found the axle is mounted in the middle of the frame, not right for a td, or a utility trailer, so I cut 14" off the back and will have to figure out how to support the front corners as the front 14" will be over the tongue. I usually have the answer to how to do something come to me while I'm doing something else unrelated (the joy of ADD)
rowerwet
Images: 521
