eamarquardt wrote:I dunno. It depends upon the output of your alternator, the size of the wire from you alternator to the battery, the type of battery you have, and maybe other factors.
You might drain the battery down, make a dummy plug with the battery charge lead and ground stubbed out. Put the battery in your trunk and drive around as usual keeping a log of how long you drive and how long it takes to bring you battery back up to charge.
If you're gonna be camping where there is shore power a 4 amp (or more) charger, running 24 hours/day will provide you all the power you need (unless yer a real power hog) as it will keep your battery topped off all of the time and when you need more than 4 amps (or whatever the capacity of your charger is) your battery will supply the excess demand.
Given a battery and a reasonable charger I have never seen the need for one of the converters. They do, though, charge the battery but their capacity is far in excess, IMHO, for what I'd ever need.
Hope this helps.
Gus
E U G wrote:Thanks for the reply! Could you elaborate more on the charger/offshore power? This is my first time camping in a trailer/RV. Just tents in the past. My trailer has a 3 prong plug in, does this mean a charger is built in? If I have something plugged into the outlets inside while trailer is plugged in will this use battery power or shore power? I guess I'm wondering if shore power is for charging only. Thanks!
Techguy wrote:E U G wrote:Thanks for the reply! Could you elaborate more on the charger/offshore power? This is my first time camping in a trailer/RV. Just tents in the past. My trailer has a 3 prong plug in, does this mean a charger is built in? If I have something plugged into the outlets inside while trailer is plugged in will this use battery power or shore power? I guess I'm wondering if shore power is for charging only. Thanks!
Your shore connector MAY only power the 110 outlets in your rig.
Your shore connector MAY charge your battery via a charger plugged into the 110 circuit of the trailer.
You shore connector MAY connect to a converter that produces 12V but switches over to 110 when connected via the shore connector
You shore connector MAY connect to a converter that produces 12V AND switches over to 110 when connected AND provides 110 from the batteries when disconnected.
I can't really see that if your builder added a 110 shore connector that they didn't also add outlets.
I would say you need to determine what is in YOUR rig. Each one is different either based on customizations requested by the original dealer or purchaser or it may vary based on "manufacturing improvements" by the builder and each rig being slightly different. Some of this is due to actual improvements other times it will be that the builder could not get the "normal" batter/converter/... in the right time frame or price range for the current build.
This is one way to test, connect your shore connector and plug in a radio or lamp to each of the 110 outlets to see if you have power at the outlets. Test your 12 V lamps to see if they are working when connected via shore connector, then unplug the shore line and see if the 110 outlets still work. Also, when you connect or disconnect your shore line, you may see the 12 lamps "dim" or "get brighter" when the shore is connected or disconnected. You may also be able to hear a slight buzz if you have a converter built in. Some converter will charge your trailer batter, other don't. Some have a stand-alone trickle charger plugged into the trailers 110 circuit.
Sorry for the long winded... it depends.
E U G wrote:I read on this forum that it's best not to run the battery below half power. Is this correct?
MtnDon wrote:E U G wrote:I read on this forum that it's best not to run the battery below half power. Is this correct?
If you want to get decent life from the battery, yes, 50% discharge should be the maximum before recharging soon. More discharge will noticeably shorten battery life if done all the time. Once in a while is ok but not ideal.
On a 12 volt battery full charge is 12.7 volts.
70% is 12.32
60% is 12.06
30% is 11.75 and getting into the danger zone
dead is 10.5
Those voltages are what would be measured at the battery after sitting idle, no charging and no discharging for 3 or so hours. (info from AZ Wind-sun... scroll down to find chart on voltages and state of charge.
Use as much as you want? Without knowing the loads you'd run and for how long, nobody can really give you a reliable answer to that. The best thing is to use your system and monitor the state of charge. Either the voltages as noted or best, using a hydrometer.
E U G wrote:I did find out that my 110 outlets only work if I'm plugged in though. Seems kind of silly to me. Why would all the interior and exterior lights work off the battery and the 110 outlets be wired this way?
E U G wrote: So that's good to know a 2-hour drive would charge it up pretty good.
Users browsing this forum: Bing [Bot] and 11 guests
