Novice Question
Novice Question
Postby bjeppson » Mon Oct 08, 2012 4:10 pm
How do you fasten the side panels to the trailer frame especially if you do not want to see the bolt heads?
Bob
bjeppson
Re: Novice Question
Postby mikeschn » Mon Oct 08, 2012 4:14 pm
Hi Bob,
I assume you've already seen these plans... http://www.mikenchell.com/images/GenericBenroyPlans.pdf
Your best bet is to attach the sides to the subfloor, with exterior drywall screws. You'd bolt the floor to the chassis.
Hope that helps.
Re: Novice Question
Postby WesGrimes » Mon Oct 08, 2012 5:06 pm
I used perforated angle iron and torque bit head flat head machine screws every 6 inches. The angle iron goes inside the trailer, and the bolts have permanent lock title for the nuts (inside trailer). I fiberglassed over the heads, so permanent was important :shock:
The angle iron is secured to the deck with SS wood screws. Go find a Fastenal store, much better selection than the big box stores.
WesGrimes
Images: 31
Re: Novice Question
Postby Woodbutcher » Mon Oct 08, 2012 7:17 pm
I attach the floor to the walls and then bolt through the floor into the trailer.
Woodbutcher
Re: Novice Question
Postby absolutsnwbrdr » Mon Oct 08, 2012 9:44 pm
Depends a lot on how your walls are constructed and how you plan on finish the exterior. Both of my builds had solid 3/4" walls and painted exterior finishes.
On my first build, I used carriage bolts and attached directly to the metal frame. On my second build I used lag bolts and attached the sides to 2x4 wood framing. In both cases I countersunk the bolt heads just enough to putty over with wood filler.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: Novice Question
Postby bjeppson » Tue Oct 09, 2012 8:25 am
Thanks folks, I was trying to envision screwing into the center of a 3/4" edge piece of poplar and having it be substantial structurally. The 2 x approach or the angle iron approach seem very plausable though it sounds like many folks have used the 3/4" base very successfully over the years. Didn't the builders of vintage trailers use 2x4 which was probably dimensional in the 30's and 40's?
Thanks again,
Bob
bjeppson
Re: Novice Question
Postby DMcCam » Tue Oct 09, 2012 9:41 am
There a tons of ways to attach the walls to the deck and the deck to the chassis. Here's a link from the construction tips section: http://www.tnttt.com/viewtopic.php?f=21&t=19442
For my build we used 1" deck plywood (1 1/8") bolted to the chassis frame with welded angled tabs. We then attached the walls to the deck using long exterior deck screws and PL Premium glue. The walls extended all the way past the chassis frame so the PL Premium glue was used there too. We then filled the holes and sanded flat as prep for the aluminum skin.
Dave
DMcCam
Re: Novice Question
Postby bjeppson » Tue Oct 09, 2012 12:05 pm
Thanks to all of you. I have a good idea of how to proceed.
Bob
bjeppson
