We have a wood stove/heater in our lounge room that heats the entire house. It has a flue tube from the top of the heater that extends about 5 feet above the roof. There is a second flue tube from the roof down to the ceiling and then 6 inches lower. There is a 1" gap between these two flues. A third flue extends from the lower end of the second tube and terminates at the roof line in a collar that seals all three tubes. There is again, a 1" gap between the two outer tubes. There is some form of insulation between the main flue and the second one. The sizes of these tubes are,
The main flue, 6" dia, stainless steel, about 18 gauge.
The second flue, 8" dia, stainless steel, about 18 gauge.
The third flue, 10 inches dia. stainless steel about 18 gauge.
There is NO SILICON used whatsoever. Silicon is very dangerous if it should become overheated, it will reduce to release highly toxic fumes that will kill you very quickly. When the fire is stoked up on a cold night and or day, (5 deg, C in the tropics), the main inner flue almost glows from the top of the heater to about 2 1/2 feet above the top of the stove.
Five deg. C I hear you say? Stop laughing! this is freezing cold for us down here.
We are very fortunate in living where we are. The temp in summer rarely goes above 38 C. Living within the coastal area of the Coral Sea, we are cooled by the prevailing South East winds that sweep across the Pacific Ocean. The nearest city to us is 38 Klms west and averages 8 or 9 degs. C hotter, last week, we were 10 degs cooler, wonderful.
Kody
Never be afraid to ask questions here, Prov. 11:14
