Doors Too Heavy
Doors Too Heavy
Postby NightCap » Fri Oct 26, 2012 7:58 pm
I did a search and came up with no suggestions on how to lighten up a very heavy door.
Some if the ideas I have are:
1. I thought I could cut out panels and put in 1/4" ply in the space.
2. I could rout out the excess wood on the back of the doors.
3. Build a door from scratch.
Any Ideas welcome.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Re: Doors Too Heavy
Postby mikeschn » Fri Oct 26, 2012 9:41 pm
Build a new door from scratch.
Use narrower ribs inside the door, and use thinner plywood for the skins! :thumbsup:
Re: Doors Too Heavy
Postby Kody » Sat Oct 27, 2012 7:05 am
It would help if we knew the size of the doors and original thickness. A method you could use is to make a new door from the dense pink foam. The panel could then be covered in 1/8th ply and fiberglassed. A narrow frame can be constructed to mount the hinges and the lock. The foam could be 3/4" thick or even 1/2". The ply skins should be glued on with laminating epoxy and weighted down. This would make a very light door and it would also have fantastic strength and stiffness.
Just a thought,
Kody
Never be afraid to ask questions here, Prov. 11:14
Kody
Images: 22
Re: Doors Too Heavy
Postby NightCap » Sat Oct 27, 2012 1:03 pm
Thanks guys, great ideas. Didn't even think of ridged foam.
NightCap
Images: 259
Users browsing this forum: Google [Bot] and 14 guests
