Miss Piggy Picture
Miss Piggy Picture
Postby Vedette » Sat Nov 17, 2012 1:28 pm
Hi this is a test.99708
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Miss Piggy Piture
Postby jeffmutch » Sat Nov 17, 2012 1:31 pm
What a tease... :cry:
Those people that constantly need a pat on the back to feel proud of thier accomplishments typically don't go very far...
jeffmutch
Images: 9
Postby Gage » Sat Nov 17, 2012 1:32 pm
I like this size better. Also, I'll be sending you a PM answering your question about the sig block. ;)
Image Image Image
Gage
Images: 28
Postby Gage » Sat Nov 17, 2012 2:44 pm
biziedizie wrote: Gage did you have to re-size that and if so what size did you go with?
Just wondering as the pic Brian posted I just click on it and it blows up.
Nope, that's the size that came up when I clicked on it in his album. This is the coding I used. :thinking:
http://www.tnttt.com/gallery/image.php?album_id=45&image_id=99708 (Image-URL)
Image Image Image
Gage
Images: 28
Postby Vedette » Sat Nov 17, 2012 4:10 pm
Thanks Gage
I copied it from your PM and plugged it in and Inow I have what you see????
Thanks Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Miss Piggy Picture
Postby Vedette » Sat Nov 17, 2012 6:43 pm
Okay ....Pictures!
I have successfully down loaded or up loaded (don't quite have the lingo down pat yet?) 16 new pictures to my Album.
I will give you a taste....not a tease.997619975999758
I know these are big and hope i can get all three in at once.
For those of you that are guests here on the forum, join now and enjoy the FULL bennefits of being a member of this Great Forum and the Great People that are here.
Thanks Steve and Gage for all your help today.
Good Roads
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Okay ....Pictures!
Good Roads
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Vedette » Sat Nov 17, 2012 6:47 pm
not quite what I expected?
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Vedette » Sat Nov 17, 2012 6:52 pm
Another picture.99749
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Vedette » Sat Nov 17, 2012 6:54 pm
Once again not quite what I expected??
Thought the picture would be larger as was the first one I posted????
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Vedette » Sat Nov 17, 2012 6:58 pm
Now the first one is small???
I am confused again.
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Gage » Sat Nov 17, 2012 7:05 pm
Is this the size you were looking for? If so when you click on the thumbnail and the larger picture comes up, copy the 'Image-URL', paste it to your post, highlight it and hit the Img button. That should put the tags before and aft of the pic address and away you go. Simple. ;)
Image Image Image
Gage
Images: 28
Postby mikeschn » Sat Nov 17, 2012 7:47 pm
This might clear things up a bit...
viewtopic.php?f=26&t=53511
Postby M C Toyer » Sat Nov 17, 2012 11:10 pm
Brian -
What I've seen so far is immaculate. Congratulations, you are at master with metal.
Does the shelf over the coolers lift off or slide back under the one behind it?
M C
M C Toyer
Images: 11
Postby S. Heisley » Sat Nov 17, 2012 11:17 pm
M C Toyer wrote:Brian -
M C
I was looking for the right words and that sums it up! ...Wow....
What do you plan to use for Miss Piggy's "nose"?
