droid_ca wrote:I'm looking at putting a wood stove in my trailer, but I know it wont run all night long ...so here is what I'm going to do (1) I want to build a hearth out of soap stone as it is the best for radiating the heat back that it has absorbed (2) ceiling fan that blows the heat down so it doesn't just go out the top (3) Extra insulation up top to prevent heat loss (4) And last but not least a Propane furnace as a back up heat source set at a certain temperature..soon as it starts to get cold it kicks in....Those are just some of the ideas that I have in mind and will be going into my build
Vedette wrote:Hopefully my e-mail will clear up your heater delema?????
Brian
Bogo wrote:
BTW, if you were getting things red hot, you were running a way too hot of fire. Slow the combustion down. Use the air inlet dampers to do that. I suggest reading up on proper care and feeding of a wood stove.
Mikka wrote:Bet you all that original poster was burning soft wood like scrap of 2x4 which flash burns with extreme heat but has no capacity to produce coal. If like said, hard wood had been used, that stove would have been full of hot coal with no room to add more wood in no time.
As well poster does not mention type of bricks if regular house bricks they are too porous to absorb heat well, it is like trying to heat soil. What is needed is fire bricks specially made for fire place, stoves etc. and available at places like HD
mj1angier wrote:check out the small stoves here http://ammocanstove.com/. They may work for some of you.
